Old 03-15-2008, 11:31 AM
hsgreer is on a distinguished road
Comments Needed-Wood vs. Metal in Garage shop
I would like to build a CNC router and have looked at several designs and read many of the threads regarding DIY machines (Solsylva, Joe's 2006, Pilot Pro). Whatever machine I choose will be built and used in my garage (I live in Utah outside of Salt Lake City). The garage has no heat or cooling. It's relatively dry here, but there would be huge temperature swings. After investing the time and money to build one I would want it to last and keep it's tolerance. So what would you use, wood or metal?
Thanks,
Steve
Old 03-15-2008, 01:07 PM
cam1 is on a distinguished road
I'd recommend using steel, provided that you have the skills and tools available to weld, and or machine. From a strength and resistance to distorsion/time standpoint steel would be my choice. I'd not be too concerned with the temperature swings, as long as the temperature doesn't radically change during machining. Depends on what you are building...precision cabinets, or hobby stuff.
regards
SE Michigan garage shop choppersprocket Mentors & Apprentice Locator 7 07-11-2007 01:40 PM
Detached Garage Shop - CNC Choice hflwaterski DIY-CNC Router Table Machines 7 11-30-2006 12:32 PM
Comments and help needed marcusb Stepper Motors and Drives 12 06-12-2006 04:56 PM
Comments needed for this design...thx! andyew DIY-CNC Router Table Machines 12 08-31-2004 03:59 PM
Wood or metal cncman2 DIY-CNC Router Table Machines 5 04-01-2003 07:17 AM
