Old 07-31-2004, 10:16 AM
I'm getten there!
dmgdesigns is on a distinguished road
80/20 vs TSLOTS question.
Does anyone know if TSLOTS fasteners like T nuts and double end fasteners will work with 80/20 extrusion? The space inside the TSLOTS extrusions seems to be a little bigger than 80/20.
Has anyone used the TSLOTS fasteners with 80/20?
Mark
DMG Designs
League City, Texas
Old 07-31-2004, 12:50 PM
High Seas's Avatar
Gold Member
High Seas is on a distinguished road
Can't speciffically answer that question, Mark - but I have used garden variety carriage bolts. I've slipped the head into the slot and then fastened things to the 80/20 that way. Use the same approach with my home brewed "tslot-table."
Jim
Experience is the BEST Teacher. Is that why it usually arrives in a shower of sparks, flash of light, loud bang, a cloud of smoke, AND -- a BILL to pay? You usually get it -- just after you need it.
Old 07-31-2004, 12:59 PM
samualt is on a distinguished road
dmgdesigns:
I'm pretty sure they fit each other. I bought some 80/20 surplus and then bought mounting hardware of all types from T-slots Inc. It works just fine. Just make sure it is the right "series". Both companies have 10-series and 15-series.
Old 07-31-2004, 01:07 PM
I'm getten there!
Thanks samualt The fastners did not have specs in the catalog.
Thanks High Seas I had not thought of that. Sounds like a good option for bolting the aluminum table top to the 80/20
Mark
DMG Designs
League City, Texas
Old 07-31-2004, 01:25 PM
"...did not have specs in the catalog."
If you already have the extrusion then compare that to their extrusion section and you'll know what series you have. From there can pick what you need from the fastner section of the catalog.
As a rule of thumb, if your extrusion is 1.5"x3" then it's 15-series. If it's smaller then it's 10-series.
T-slots Inc is cheaper than 80/20 so that is why I buy mounting hardware from them.
3D Modeling with 80/20 Extrusion NEATman 80/20, TSLOTS and other Aluminum Framing Systems 6 04-16-2009 06:28 PM
Extremely basic machining question. touser General Metalwork Discussion 9 06-19-2005 12:51 AM
Where to find surplus Tslots or 80/20 samualt 80/20, TSLOTS and other Aluminum Framing Systems 8 11-05-2004 01:04 PM
Hobbycnc controler question chas Hobbycnc (Products) 3 09-09-2004 05:00 PM
Just a question about plunge milling. Machine1 Hard and High Speed Machining 4 01-28-2004 08:36 PM
