Old 03-13-2008, 10:50 PM
fermag's Avatar
fermag is on a distinguished road
Red face Wath do think abouth this machine
I´m planing to build a small router, something like 16"x8" of usefull area and 2.5" in z axis, i like the Soltar design, looks very simple, and I was thinking in build a machine using their guide system, and building the body and the Gantry bridge with MDF, for the guide system I planing to use some "T" shape an "L" shape of extruded aluminium, and HDPE sliders, with threaded rod (5/16"). Do you think that this could be a good machine with NEMA 23 steppers (basically I will cut balsa, plywood, some plastics and PERHAPS... aluminium)
Just a conceptual sketch
Wath kind of motor is this?? (Look at the pictures) patriciooholegu Servo Motors and Drives 6 10-10-2007 06:42 PM
Deep Groove Taig machine would it be a good starter machine Fritzie15 Taig Mills & Lathes 0 09-20-2007 09:37 PM
paper printer machine like cnc machine ??? patriciooholegu Mechanical Calculations/Engineering Design 3 08-07-2007 08:19 PM
Mach 2 on old machine = great machine foamcutter Machines running Mach Software 6 12-16-2005 12:11 PM
Getting work(gcode) from machine a to machine b strat DIY-CNC Router Table Machines 9 07-07-2005 02:13 PM
