Old 03-13-2008, 10:02 AM
xXxcalibur is on a distinguished road
350oz tormach has no torch
This is my first post so be nice I have been reading forum for a long time and I have finally built my first cnc machine. I was very excited to get it built and seeing it work. But when it came time to see it work or even just move. noooope!!!! No power!! They turn but just cannot move any of the 3 axis very fast or reliable. I have a 4axis driver with allegro chips. This board has a max 2.5 amp output. I have 24v 10amp power supply using mach 3 software
The tormach steppers are 350oz @3 amp. So I know my motors cannot operate at max torch. I 2.5 amps would put it around 80% but that still should be enough to move the axis. I am using .5'' acme rod with 20mm
linear shafts with bearings. The problem looks like they are binding up or something. I just cannot figure it out. I can turn them my hand and they turn free. And the slide motion is smooth. I was hesitant about posting but I have come to a cross roads and need some help. I dont know if this is even a good place to post. If some can send me to the right string or direction. I would appreciate it
Old 03-13-2008, 10:14 AM
ger21's Avatar
What brand is the drive, and is the VREF set correctly?
Old 03-13-2008, 10:30 AM
Yes
I set the vref ..... I believe it was 3.8 volts. You will have to forgive me I am at work I don't have the paper here. Thanks for your reply
In mach if you set to lower acceration and velocity do you have more torch?
Old 03-13-2008, 10:32 AM
the Board is Mechatronics
Old 03-13-2008, 10:49 AM
Gir Gir is offline
Gir is on a distinguished road
The acceleration is rarely a problem, but the speed is. A lower speed will give you a lot more torque. What's the TPI on your acme thread and how fast are you trying to run the machine? Have you tried 10-20 IPM?
Old 03-13-2008, 10:57 AM
In mach I have been adjusting the velocity and accel. i guess what I should ask is how fast should I have it moving? Where should the velocity be set. I don't no what thread the acme rod is!
oxy gasoline cutting torch - oPetrol cutting torch denniswang Product Announcements & Manufacturer News 6 02-20-2010 04:23 PM
Plasma Torch Dembo CNC Plasma and Waterjet Machines 5 09-26-2008 01:27 PM
Need Help!- Different between hand torch& machine torch ltran2000 CNC Plasma and Waterjet Machines 7 03-02-2008 09:19 AM
Gas Torch Sanghera CNC Plasma and Waterjet Machines 40 05-20-2006 11:29 AM
