Old 03-12-2008, 08:28 PM
eloid is on a distinguished road
diy gearhead
need someone to confirm my thoughts
when designing a two stage gear box with timing blets or spurs gears
you just multiply the 2 stages or add them?
ie both stages are 3.5:1 70 teeth and 20 teeth when both stage are combined... is the gear caluation stage1 x stage2=12.25 a 12.25:1
or stage 1 + stage 2=7 a 7:1 ratio
please advise
Old 03-12-2008, 08:30 PM
BobF is on a distinguished road
multiply
Old 03-13-2008, 04:07 AM
mc-motorsports's Avatar
mc-motorsports is on a distinguished road
12.25:1 is what I come up with
Old 03-13-2008, 05:58 AM
thanks
thank guy for the quick replys, has any one make a 2 stage gear box, look
for some ideas to use with a rack and pinion design.
Old 03-13-2008, 06:19 AM
LazyMan is on a distinguished road
Take a look at Greolts build.
http://www.cnczone.com/forums/showthread.php?t=28979
He made a very nice gearbox with 4:1 reduction useing 60 and 15 tooth pulleys. I designed one based on his design.
Gearhead selecting bullethead67 CNC Plasma and Waterjet Machines 5 10-14-2007 03:20 PM
Rotary Position device... Belt VS Gearhead 54Oval Mechanical Calculations/Engineering Design 20 03-08-2007 11:49 PM
How to remove gearhead cover? FlyingIllini Benchtop Machines 3 02-25-2007 01:39 PM
can i use this gearhead ? max_imum2000 Linear and Rotary Motion 3 01-27-2007 08:02 PM
Planetary gearhead vs timing belts Swede General Metal Working Machines 4 03-27-2005 08:19 PM
