Old 03-11-2008, 10:54 AM
ramasule is on a distinguished road
Quicky Lube, Grease
What lube / grease should I use on my linear bearing tracks?
What Lube / grease should I use on my leadscrews?
Im looking for the home depot / canadian tire solution.
Thank you for your time,
Derek L
Old 03-11-2008, 10:45 PM
mcyr is on a distinguished road
For my leadscrews I use just plain old lithium grease. A little dab does the trick.
Mike
Old 03-11-2008, 10:46 PM
where do i get that stuff
Old 03-11-2008, 10:50 PM
If its not at HD or Lowes, then try an auto parts store. Shouldn't cost more than a couple of bucks...at least in todays dollars.
Old 03-12-2008, 02:31 AM
Cartierusm is on a distinguished road
What kind of nuts are you using on your lead screw and what kind of linear slides, because a lot of both don't need anything and will actually hurt them, namely attracting dust and creating friction and blockage.
Old 03-12-2008, 06:07 PM
bearing is vxb 20mm pillow block and thk slide track or something
acme 1/2 10 2 rod with delrin nuts.
Old 03-12-2008, 08:03 PM
You don't need any lube on those. If you did you would gunk them up. Delrin is a teflon type of material and is slippery on it's own.
Cleaning off the grease Involute Syil Products 5 04-16-2007 01:36 PM
#1 grease? Have Blue Tree 11 12-03-2006 08:24 AM
M6 x 1.0mm grease fitting N4NV Mechanical Calculations/Engineering Design 5 03-31-2006 04:03 PM
oil or grease? hpghost DIY-CNC Router Table Machines 2 08-30-2005 02:20 PM
grease?? DLMACHINE Machine Problems, Solutions , Wireless DNC, serial port 0 04-22-2004 12:27 AM
