I have a question. I was wondering how a ball mill used for milling metal would cut wood, actually ebony inlayed with mother of pearl. It doesn't have to be very smooth because final sanding will take care of that. My question is are they sharp enough? I don't know if they use different kind of sharpness for metal cutting bits? I have used a round nose router bit and it seems to do a decent job but knowing wood cutting bits the mother of pearl is going to dull it pretty quickly, and I think it is all ready. Below are links to what I'm using and what I want to use. Any help would be appreciated. Thanks Link to the round nose router bit I'm using now, 3/4" diameter: http://www.amanatool.com/bits-fv/45960.html Ball Mill I have an would like to use, 3/8" Diameter: http://grizzly.com/products/TiN-Coat...3-8-Dia-/G9880 |
| Mother of pearl is not that much different to rock, at least from the perspective of a cutting tool. Are you using carbide tools, I would expect high speed steel to have a short life and even carbide is going to dull much quicker than it does on metal or wood.
| Ball nose and Chamfer endmills ? Finishing & Roughing? | Rich05 | General Metalwork Discussion | 2 | 11-01-2007 05:25 PM |
| Source for large qty of cheap linear ball bearings - round shaft | InspirationTool | Linear and Rotary Motion | 2 | 01-10-2007 09:00 AM |
| Tool: Ball Nose definition in BobCad | rherman | BobCad-Cam | 5 | 09-20-2006 03:48 PM |
| Help! Why Round Column Mills not fit to convert to CNC? | szcharle | Benchtop Machines | 17 | 08-01-2006 06:03 PM |
| End mills, Ball Nose, Vcarve? What's your default set? | PEU | DIY-CNC Router Table Machines | 3 | 10-26-2005 10:38 AM |
