03-12-2008, 09:14 AM
The power supplies are switch mode supplies.
I did some tinkering last night and replaced the 470uF 63V decoupling capacitors with some 520uF 100V and it seems to have removed the pulsing noise.
Reply With Quote |
Ahhh, switching supplies are nice, very light! I'm surprised you were getting pulsing from that - 470 to 520 uF shouldn't have made a huge difference. I guess if you're pushing the limits of the supply it will do that though.
Since you're pumping a lot current through your drivers, just to make sure you're not hurting anything, hold your hand on your gecko's after they've been running for a while. If they feel quite hot, you might was some fans (or a current limiter) in there. If they only feel warm you're fine.
Glad to hear it's working better, though! |
