Old 03-06-2008, 11:01 AM
skipper_52 is on a distinguished road
Building 1st router.
After looking at quite a few plans I decided to start with Solsylva and bought my steppers from Xylotex. I understand the limit switches and emergency stop setup, but am having a difficult time finding anything on wiring for "home". Apparently this feature is not available directly on the xylotex board and needs to be hardwired somehow. (great!). Does anyone know a good place to start reading about building and setting up the home switches for a complete idiot. I plan on using Mach 3 if that helps. Will post pics of my machine as I build it. Appreciate the help.
Old 03-06-2008, 11:09 AM
ger21's Avatar
The home switches are wired just like the limit and estop, and homing is controlled by mach3. You might want to read through the mach3 manual, even though it's a bit out of date.
Old 03-06-2008, 06:44 PM
CarveOne is on a distinguished road
Take a look at these links. They may have just what you need:
http://pminmo.com/PMinMOwiki/index.p...limit_switches
http://www.solsylva.com/cnc/xylotexdrive.html
http://www.solsylva.com/cnc/limits.html
CarveOne
"A $1,000 electronic device will almost always protect a ten cent fuse."
building a cnc router TheCrazzyman Mechanical Calculations/Engineering Design 3 10-06-2006 01:05 PM
Building My Second Router snazzyguy CNC Wood Router Project Log 10 04-30-2006 06:32 PM
Building a Cnc Router Cold Fusion CNC Wood Router Project Log 399 11-22-2005 02:08 PM
Building my second cnc router balsaman CNC Wood Router Project Log 267 10-11-2004 03:15 PM
How many building the cad cut cnc router? jsatter DIY-CNC Router Table Machines 7 07-26-2004 04:10 PM
