Old 07-27-2004, 08:27 AM
Mr.Ed's Avatar
Scrapheap Scavenger
Mr.Ed is on a distinguished road
Tried using Teflon?
Hi guys,
In my first machine i used 12mm threaded iron rod for transporting the gantry. The nut is made of a copper-zink alloy (Messing, dont know the English word).
It works, i compensated backlash by means of two springloaded nuts, no fancy stuff. But it's no ballscrew.
So i started thinking of using Teflon. Dont know the English word either, but it's the stuff used in cooking pans. (duh... )
Anyway, did anybody recently try this with teflon? It's tough, it's wear and heat resistant and it slides like...well, more like a ballscrew than copper-zink does.
Being tough, it might be hard to drill accurately, and tap 12mm thread into the hole.
Anybody want to share thoughts about this? A beer for the first reply!
Thanks,
Ed.
Not the horse, of course of course...
Building my own Scrapheap challenge CNC, or is it Junkyard wars CNC?
Old 07-27-2004, 09:35 AM
duluthboat's Avatar
duluthboat is on a distinguished road
I could use a pint.
Teflon is very easy to machine, it requires very sharp tools and several clean up passes to get tight tolerances. I think it would make a backlash free nut, but I’m not sure how strong it is and it suffers from contamination. What I have been thinking about is to put Teflon inserts into a standaed nut that could be tightened and replaced.
Gary
Chagrin is on a distinguished road
Teflon works, but I think Acetal/Delrin is better. Acetal has a slightly lower coefficient of thermal expansion (nobody likes it when their nuts tighten up from the heat, right?) and is just easier to machine.
Old 07-27-2004, 02:09 PM
Mr.Ed's Avatar
Scrapheap Scavenger
True, but...
Right from the start, when i began building my machine, i had difficulties in getting the right materials. So Delrin / Acetal... pooh.. I dont know about that, though i take your word for it that it is better than Teflon.
Another hobby of mine has to do with Radiotransmitters and all that. Teflon is relatively easy to come by when you're in High Frequency stuff. I could get kilos if i wanted to.
That, sofar, has been the greatest challenge when building a machine in Europe. Just where to get your materials. Shure, there must be resources, we're no dummies. Sofar most of my stuff comes from Ebay, US. Add taxes and postage and you see my problem(s).
Anyway, Duluthboat, CHEERS !
I see some strong points in your comments. keep them coming !
Ed.
Old 07-27-2004, 02:41 PM
BigDaddyG is on a distinguished road
Hello All,
Don't forget the casting Polymers! Take a small peice of thread and a tube, and cast a perfect anti-backlash nut! With todays technologies this stuff is avialable all over the place and cheap. Take some care with the set-ups. I have been machining threads on tubing (or you can use any mounting configuration like all the common anti-backlash nuts out there), machine a small plug for one end (which can be used over) and pour the casing full of Plastic! You get a perfect nut, with Metal outside and your ready to go! One quart of casting compound will last for a very long time and make many nuts, and drive others nuts trying to figure out how you did that (Take if from me, I know)!Cheap, long lasting and you will impress your friends!!!!!!
Good Luck All,
Glen
Old 07-27-2004, 04:38 PM
*Registered*
ESjaavik is on a distinguished road
One problem with Teflon(Tm) or PTFE is that it's not holding a shape. I have a 2m long rod of 25mm PTFE. I had it lying on top of some other things, and when I needed it the rod was far from straight. It had followed gravity and taken that shape. The fix was to put it into a straight tube, and after a while it was straight again.
I believe the polymer casting idea. It shrinks appx. 0,1mm when cast in 3mm thickness. Hopefully that will not tighten it around your rod but rather create the needed room for lubricant. Remember the release agent on your threads.
Old 07-28-2004, 07:05 AM
DareBee's Avatar
Monkeywrench Technician
DareBee is on a distinguished road
Teflon has an extremely poor tensile strength rating. Definately would not be my choice.
If you want to use thermoplastic I suggest Nylon 6/6 or Delrin.
You can actually purchase Nylon hex nuts from fastener suppliers here.
Old 07-29-2004, 08:43 AM
RotarySMP's Avatar
RotarySMP is on a distinguished road
Hi Ed,
I used Moly disulphide impregnated nylon "Nylotron" nuts from www.maedler.de for my Z axis leadscrew nuts.
Regards,
Mark
www.wrathall.com
Old 07-29-2004, 02:11 PM
Mr.Ed's Avatar
Scrapheap Scavenger
Hmm, interesting...
Thanks Rotary,
I started looking through the products that they have and it looks promising. The case is, i'm allso looking for Schneckenräder . Unfortunately, they don't go higher than 150 teeth. I would need something like 320 or so...
Anyway, thanks for your contribution. I'll be looking into it...
Thanks,
Ed.
Old 07-30-2004, 01:57 AM
RotarySMP's Avatar
Hi Ed,
Here is a write up on making your own worm gears.
Why 320:1?
Mark
Regards,
Mark
www.wrathall.com
  #11   Ban this user!
Old 07-30-2004, 02:01 AM
RotarySMP's Avatar
Oops, here it is...
http://bedair.org/Worm/Worm.html
Mark
Regards,
Mark
www.wrathall.com
Old 07-30-2004, 07:07 AM
Mr.Ed's Avatar
Scrapheap Scavenger
Owh my goodness!
That's it !
It's meant for my Telescope, you guessed it !
The example is for 200 teeth. I mentioned 320 teeth. Both are fine i guess. There seems to be a standard rule of thumb stating that the diameter of the Wormwheel should be about the same size as the diameter of your Telescope's tube.
My Telescope is 200mm across, and i would like to make or buy me a Wormwheel of 200mm in diameter. That would come to something like 200 up to 350 teeth, depending on teeth distance.
This is only the second site that i encountered ever, that explains making your own Wormwheel. Amazing !
Something tells me that you know more about the subject!
Start talking, you got my attention now !
Ed.
Hoping it works! Guy Smiley CNC Wood Router Project Log 60 03-04-2006 08:30 AM
Linear Guides with Teflon Bearings cely General Metal Working Machines 0 03-19-2004 04:05 PM
