Old 03-05-2008, 04:31 PM
jeffmorris is on a distinguished road
Steel tubes for bearing tracks
I am building a 17X20 overhead leadscrew CNC machine following the plans from Solsylva. The plans called for 1/2-inch ID conduit and 3/4-inch ID gas pipe. I found conduits that have ID of 5/8 and 1-inch, and OD of 3/4 and about 1-3/16 inches. Will these work?
Old 03-25-2008, 12:16 PM
mlammert is on a distinguished road
We just finished building the large double-lead screw plan for his book...
I cannot answer your question specifically since I am currently at work, but you basically want to just go to Home Depot or Lowes and get their 1/2 inch electrical conduit and their 3/4 inch gas pipe...
Most of his materials are simply big box parts except for a few that you need to order...
We just finished our machine last weekend and are starting to get into the guts of the software...
Good luck,
Mark
Hardened steel tubes, suitable for frame cnc router ? vroemm Mechanical Calculations/Engineering Design 2 07-09-2007 03:29 AM
Steel tubes Stoneair666 General Metalwork Discussion 5 03-30-2006 08:19 PM
DIY Pick'n'Place component selection and solder station: not PCB routing, tracks, etc gocad Linear and Rotary Motion 4 08-16-2005 06:46 PM
Sliding door tracks and rollers Apples CNC Plasma and Waterjet Machines 1 06-10-2004 08:34 PM
sliding door and window tracks Apples DIY-CNC Router Table Machines 2 04-10-2004 09:51 PM
