On about 46" of length which is better lead screw or ball screw? Also what diameter would be best? Right now I have 1/2" dia acme screw and it whips alot at 75 ipm. Could someone list the pros and cons of each? |
| Is your acme 1/2-10? if so, you might want to try 2 start 1/2-10, which would only turn half as fast. It will also only have 1/2 the torque, though. If you're trying to eliminate the whipping, a ball screw or an acme with the same lead should'nt be much different. A ball screw is more efficient, though. But, you'll need to keep the dust from getting into the ball nut or you could have problems with it.
| Maybe a ballscrew a little, but not much. go to http://www.nookind.com and check out their catalogs. they have charts showing the max speed you can spin the screws before whipping occurs (critical speed).
To all, I am designing a router with an effective working surface of the size of an A3 paper (2 x A4) and I do not know what size screw i have to take. I find that there are many different "acme" (tapezium) screw types and sizes. What leadscrew is needed? If one has the oportunity to use a screw of tr10-2 oposed to tr14-2 and tr16-2 What would be the best choise? Willy |
| Lead screw whip | spalm | DIY-CNC Router Table Machines | 3 | 05-24-2005 02:04 PM |
| Upgrade to a 1 inch ball screw with a .5 lead...??? | bgolash | DIY-CNC Router Table Machines | 10 | 01-25-2005 08:37 AM |
| Compensating for ball screw lead error? | Noah | General Metal Working Machines | 2 | 08-12-2004 08:51 PM |
| ball screw lead amount | replicapro | General Metal Working Machines | 17 | 07-03-2004 07:59 AM |
| Ball Screw and Lead Screw | ljoe1969 | DIY-CNC Router Table Machines | 9 | 11-21-2003 08:06 AM |
