Old 05-05-2003, 08:44 PM
ger21's Avatar
Limit Switches
What do you guys use for inexpensive limit switches. Or do I have to spend a little more money for good switches. Sources? Any help appreciated. Thanks.
Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiTweet this Post!Share on Facebook
Old 05-05-2003, 09:38 PM
balsaman's Avatar
balsaman is on a distinguished road
I used cheap microswitches I bought surplus. (Princess Auto if you are in Canada)
Eric
I wish it wouldn't crash.
Old 05-05-2003, 09:39 PM
boxwood is on a distinguished road
Check out the miniture limit switches half way down
http://www.mscdirect.com/PDF.process?pdf=3792&Keyword=Y
Old 05-06-2003, 12:42 PM
HomeCNC's Avatar
HomeCNC is on a distinguished road
It's not rocket science. Just go to Radio shack!
Jeff Davis (HomeCNC)
http://www.homecnc.info
Old 05-06-2003, 11:15 PM
ger21's Avatar
Those little $3 ones from radio shack will work just fine then? Thanks
Old 05-07-2003, 10:41 PM
balsaman's Avatar
Yes.
Eric
Help with limit switches and Xylotex board dowling177 Xylotex 5 11-26-2008 03:51 PM
Limit switches itsme General Electronics Discussion 5 05-01-2005 06:02 PM
The relationship of limit switches to home switches. MikeAber General Electronics Discussion 4 11-04-2004 02:28 PM
Limit switches and home switches viktorcnc TurboCNC 2 08-03-2004 07:11 AM
Home switches and limit switches. ynneb General Electronics Discussion 5 04-08-2004 06:32 PM
