Old 07-25-2004, 11:51 AM
Moondog is on a distinguished road
Travel Speed Ratios???
I know you guys can help me with this.
Just working out my Travel speeds and ratios. Disregard actual rates of travel..
What is the ideal ratio for the 3 Axis travel speeds. For example should all 3 Axis travel at the same speed i., 200 in/min or is their an ideal ration between the axis?... or should X be 2 times Y?...something...
say, your X Axis is 2 times your Y axis lenght and you wanted your machine to travel the full length and to the furtherest point. If the X & Y are the same speed then the Y axis will reach its designated point in half of the time of X or should they both meet at the same time?..
cheers
Old 07-25-2004, 12:03 PM
DAB_Design is on a distinguished road
They should meet at the same time. But this would be software controlled.
As far as haveing all 3 axis run the same speeds? X and Y should definately be the same. Some of the machines I run at work (full size), Z can only move at 200ipm where X and Y will move 300ipm. If you send all 3 axis to their furtest points, they should get there at the same time. Limited by the slowest of the 3 axis. Gearing ratios have nothing to do with that, as it is software controlled.
Old 07-25-2004, 12:13 PM
Thanks Dab Design for your reply. That gives me something to work on.
CNC Controlled Spindle motor speed control gregmary General Electronics Discussion 13 02-27-2009 07:01 PM
Speed how fast an axis can move? jlagran he General CNC (Mill and Lathe) Control Software (NC) 0 01-04-2005 10:05 PM
Spindle Speed & Feed Rates - Question Moondog DIY-CNC Router Table Machines 1 07-23-2004 06:24 PM
min speed exceeds max speed for axis "x"? ljoe1969 TurboCNC 4 01-19-2004 07:49 AM
AC Speed Control georgebarr General Electronics Discussion 7 01-06-2004 07:33 PM
