Old 03-01-2008, 03:57 PM
Timandjulianne is on a distinguished road
tslot or mdf plans
I need some advice on building a small cnc router table. I am currently using a desktopCNC router from Imservice, and I am happy with the results. I need to be able to do fine detail relief carvings. I have been carving lithophanes into corian using vcarve. I need a second machine with something stronger than a trim router. I have looked at some of the plans here on cnczone but I want to make sure they can do the detail I need. Any recommendations on which plans to use or which plans to adapt.
my budget is $500 for the table without the steppers.
Cutting area needs to be at least 8"x10" with a z of 1"
DIY Plans... cnc-newb General Metal Working Machines 0 12-03-2007 08:41 PM
Plans nev25 CNC Wire Foam Cutter Machines 6 06-08-2007 03:12 PM
Looking for plans alexis221 DIY-CNC Router Table Machines 8 12-06-2006 01:23 PM
Which CNC Plans to go with? JohnG DIY-CNC Router Table Machines 6 05-08-2006 02:00 AM
My Plans c0rpse DIY-CNC Router Table Machines 5 05-05-2006 05:09 PM
