Old 02-29-2008, 09:56 PM
cpcapace is on a distinguished road
A question on motors
How do you read motor specs? Also, how or how do you determine / tell the software where the distance of one revolution. Does that make sense?
So I'm using 1/4" 20 threaded rod. At 1 full 360 revolution, the axis would move a certain distance. How does the software know how far that distance is, so the program corelates with the rod size / thread?
Wow. I hope that makes sense?
Old 02-29-2008, 10:53 PM
ger21's Avatar
Can you be more specific in what you want to know?
................ how or how do you determine / tell the software where the distance of one revolution. Does that make sense?
The software will usually have a place where you enter how many steps it takes to move one unit. If you had 200 step / rev steppers, with 1/8 microstepping, and your 1/4-20 rod, you get 20 turns per inch, times 200 steps per rev, times 8 microsteps per step. 8x200x20=32,000 steps per inch.
Old 03-01-2008, 10:34 AM
thank you that helps
that really helps out. I'm starting my build. Using the plans similar to build your cnc.
Question on test/tuning motors ? KEYTEEM Servo Drives 1 04-10-2009 07:27 AM
question about motors and travel james12s Benchtop Machines 3 06-18-2007 11:41 AM
Few question about servo motors ... efrem Servo Motors and Drives 1 07-05-2006 10:42 PM
Question on Strength of Motors js11110 DIY-CNC Router Table Machines 37 03-25-2006 04:11 PM
Do you have a question regarding step motors? ESjaavik Stepper Motors and Drives 0 03-24-2005 02:51 AM
