Old 02-24-2008, 05:57 PM
wyldesyde007 is on a distinguished road
Poor man's T-Slot wannabe
Well I don't know if this has been shown before on this site but this is my fix for a hold down system that is both flexible (and Cheap!) . Don't get me wrong I do like T-Slot clamping systems but the only drawback I see to them is that if you want alot of different clamping positions you have to add alot more T-Slot. The keyhole system I'm using is spaced about 2" apart covering my entire table, so if I want to clamp down a part that is say 3"X 3" on all four sides I need only to locate it between 4 Keyholes pretty much anywhere on the table! If I were to have used T-Slot odds are if I didn't space the Slot 2" apart all the way across the table I would only be able to clamp the part on 2 sides.
Here's a shot of the keyholes along with the Gcode I used to make them.
Old 02-24-2008, 06:05 PM
I made up some quick clamps using pine, the ideal material would be a hard wood but I was in a hurry and i'll make some better ones when I have more time. This one is a simple leveraged hold down, the block on the back of the clamp should idealy be slightly taller than the material being clamped this creates downward pressure on your work piece. If the block were shorter the clamping pressure would want to squeeze your work piece out of it. I used a 1/4" bolt with a wing nut for quick fastening, look at how easy it is to insert!
ID:	54112   Click image for larger version
ID:	54113   Click image for larger version
Old 02-24-2008, 06:10 PM
This is another clamp based on a cam design I made up to handle items where I need the surface free of clamps. It uses another 1/4" bolt to attach it to the table then you would twist the cam to wedge the clamping block tight to your work piece.
ID:	54116   Click image for larger version
ID:	54117   Click image for larger version
ID:	54118   Click image for larger version
Old 02-24-2008, 06:22 PM
audioandy1762's Avatar
audioandy1762 is on a distinguished road
Great Idea! thanks for sharing
Andy
Old 02-24-2008, 06:57 PM
epineh is on a distinguished road
Nice work ! I am definately going to use that idea
Thanks.
Russell.
Poor man's cad (Blender) eternauta3k General CAM Discussion 14 12-10-2009 08:47 PM
11x26 Poor Man's DRO njwtech Mini Lathe 16 09-04-2008 06:09 PM
Poor Man's Cutter Table vladdy Plasma, EDM and other similar machine Project Log 5 08-19-2007 02:48 AM
Coated Carbide 4Flute Endmill, 3Flute Slot Drill, or 2Flute Slot Drill? weaston General Metalwork Discussion 7 04-11-2007 10:00 PM
3 Axis drivers (a list wannabe) Konstantin General Electronics Discussion 3 03-26-2004 01:22 AM
