Old 02-22-2008, 05:23 PM
~TM~ is on a distinguished road
Double check and offer suggestions...planning
Ok I'm gathering materials to construct a 3' x 4' cnc out of mostly 80/20 and linear slides. Therefor i hope to achieve 200ish inches/min cutting rates...maybe. Here is what i was thinking about for the axis-
KELING steppers
-nema 34 640oz (x and y axis) rated at 6A 2.4V bipolar
-nema 23 495oz (z axis) 3A 3.6V bipolar
I've read i should run these in parallel for best results right?
-Gecko 203 drivers (by what I've read they are semi-dummy proof...perfect for the electrically challenged=ME)
Ok that's what i definitely want, now what do you guys suggest for a good power supply? 36V 48V Keling? And what about a BOB? Will I need one? What would make a great friend to the geckos? Will all these components work well together? I'm just looking for experience on good combos.
And can someone double check me here on my linear path. I apologize if this sounds redundant, but before cash is thrown I want to make sure I understand.
CAD(autocad)-CAM(?)-Mach3 (this is what i'll use) - printer port-breakout board-gecko drives-steppers--voila finished artwork
Thanks for any input, I'm definitely new to this. I know how to use autocad, have ran a cnc, and am a woodworker..dangerous combo for this hobby. Thanks again
~tommy
Old 02-22-2008, 07:17 PM
Eurisko is on a distinguished road
Hi Tommy,
Sounds like you've made some good choices.
As for the power supply, the more voltage, the better. Gecko recommends 4x to 20x the motor's rated voltage, up to a max of 80 volts. An unregulated supply is fine.
You'll have to decide how you want to drive your router.
Precision ground ballscrews are the best, but out of my price range.
Rolled ballscrews are more economical, but generally less accurate.
Precision acme rods would also be a fair choice, depending on your budget.
Let's have a look at your drawings, always nice to see a new build.
Old 02-22-2008, 07:18 PM
ahren's Avatar
ahren is on a distinguished road
Sounds like you are on the right track from an electronics standpoint. The voltage of the power supplies is not crucial, but the higher the voltage, the less your torque will fall off due to back emf at higher speeds. I would say the 48V will do well. Geckos are great, and should work well with the Keling motors.
What are you planning from a mechanical standpoint? How are you going to drive your axes, and what are you planning on using for linear slides?
Ahren
www.cncrouterparts.com
Old 02-22-2008, 09:23 PM
Thanks for the encouragement guys. Have you heard much about this BOB from CNC4PC - C11G board and I guess it needs a separate power supply? And i guess i might go with a 48volt supply from keling KL-350-48 48V/7.3A
110V/230V for the drivers.
Eurisko- i'm thinking about precision acme rods 1/2 - 10 5start help me out...this means 1/2 diameter, 10 threads per inch, 5 separate running threads right? I think Joe used this setup on his new 4x4 hybrid and it seems like that should work for speed and accuracy. As far as drawings, i should have something very generic drawn up this weekend to show off and have you guys pick apart.
Ahren- tomorrow i'll take some pics of the linear slides i have, hopefully it'll give you a better understanding of what i'm thinking. I'll try to explain right now...i have THK 16mm bushings and shafts for the z-axis. For the y-axis (gantry axis) i have 30mm THK open bearings that will ride on hardened steel shafts (real nice and beefy) and for the x-axis i'm in the process of buying some THK sr25 linear dovetail rails and blocks : ) i'm using the z and x axis choices because i received them for free...but i gotta shell some out for those dovetails but hey, i wanna make something that lasts.
I will mostly be cutting wood and some plexi, etc with this router but i want to have the beef there to do even a little aluminum maybe. For now i'll use my Porta cable router as a spindle so nothing too crazy.
Like i said by the end of this weekend i should have a drawing and some pics posted of the slides i have. Stay tuned in for the beginning...
Old 02-23-2008, 01:20 AM
ger21's Avatar
I'd get at least a 10 amp supply. 7.3 might not be enough if all 3 motors are running at full power.
Old 02-23-2008, 02:15 PM
ger21- do you have a source for a 10amp power supply? Most of the 48v supplies i've found seem to peak at around 8amps. What is an unregulated power supply? Those will definitely work but they are twice as expensive. Ok so i took some pics of the slides i have.
-pic 1- 30mm open block slide and 48" 30mm hardened shaft
-pic 2- same
-pic 3- 16mm bushing and 15" shaft with tapped ends
-pic 4- same
As far as the leadscrews, what do you guys suggest? I was thinking 1/2" 10 5 start like i said, but am also considering roton ballscrews? Suggestions? Like everyone i'm trying to stay as low as possible on the price but with good results. Well gotta start drawing this thing up now, thanks for any comments.
ID:	54013   Click image for larger version
ID:	54014   Click image for larger version
ID:	54015   Click image for larger version
Old 02-23-2008, 02:59 PM
ger21's Avatar
http://cgi.ebay.com/50V-10A-Power-Su...QQcmdZViewItem
http://cgi.ebay.com/54V-12A-5V-12V-R...QQcmdZViewItem
Old 02-23-2008, 09:32 PM
Gerry is absolutely right.
A parallel connected stepper will draw 2/3 of its rated current. So, a 6 amp motor will draw 4 amps, and a 3 amp motor will draw 2 amps. This info is from Gecko's Step Motor Basics.
In answer to your question,
A regulated power supply maintains a (nearly) constant output voltage, even with varying load conditions. This is a must if you're dealing with digital circuitry, but not necessary for driving a stepper motor.
An unregulated power supply usually consists of a transformer, bridge rectifier, and filter capacitors. There will always be a slight voltage ripple at the output. Use larger capacitors for less ripple.
Old 02-23-2008, 10:29 PM
That makes sense, thanks for clarifying eurisko. The links ger21 gave are a good start on where i might get one, prices aren't too bad either as far as i can tell. I downloaded sketchup to try and draw this beast out in 3d space, but there is a learning curve. Few commands but doesn't always do what i want it to : ) I can do it in autocad but i'm very slow in 3d. Maybe i'll do some iso drawings to give an idea whats in my cluttered head. Any suggestions on leadscrews still? I'll talk more about mechanics once the drawings are posted up so you can see what i'm trying to explain.
Old 02-23-2008, 10:56 PM
Tommy,
Reid supply is a great resource for CAD drawings.
http://www.reidsupply.com/cad.aspx
They also sell precision acme rod, but probably not 1/2-10 5 start.
Their Nook rolled ballscrews look very nice, I just bought one this week !
I may save it for my next (bigger) router, still working on my 1st. Tough to work in a kerosene heated garage when the temperature is in the teens. Carbon monoxide has claimed way too many brain cells.
  #11   Ban this user!
Old 02-25-2008, 08:20 PM
I feel ya exactly eurisko, i'm in a one car garage slammed with a table saw, jointer/planer, dust collector, etc AND a Readyair kerosene heater...little cramped and crazy. Ok so i've been searching for some long rails for my x-axis. I found some thk dovetail rails around 5-6 footish that i can get for @$200 apiece. What do you guyz think? Good investment or keep searching...ebay is a bust for me : ( any sources you can suggest that's better than that i'd LOVE to here!!
Does any have or know where i can get a linear actuator for my z-axis? I'm considering this option as opposed to my 16mm bearings and shafts because the ease of it. Ballscrew is there, nice and sturdy, decent travel usually, etc.
What is a good distance from the spoil board to the bottom of the gantry also? I've heard around 15 inches, is that about right? i won't be doing anything crazy thick maybe max out material at 4-5"
Old 02-25-2008, 08:40 PM
ger21's Avatar
The higher it is, the more the Z axis will flex when it extends down to the table. Why have the Z hanging 15" below the gantry? Make the gantry as low as possible. Just be sure to account for all conditions you might see, such as jigs or fixtures to hold parts, and clamps.
Planning a 4x4 Oakley1975 DIY-CNC Router Table Machines 11 01-01-2008 03:21 PM
Trajectory planning of EMC 2.0 Hebert LinuxCNC (formerly EMC2) 1 10-16-2006 01:12 PM
can someone double-check? (powersupply) anthony Gecko Drives 1 05-09-2005 04:46 PM
need help planning russell DIY-CNC Router Table Machines 14 03-18-2005 09:18 AM
Too much planning? Hobbiest DIY-CNC Router Table Machines 7 04-26-2004 09:05 PM
