  #13   Ban this user!
Old 03-16-2008, 09:06 PM
~TM~ is on a distinguished road
Eurisko, did you ever receive your nook ballscrew? I was browsing through Reids sight and saw mostly thomson ballscrews. What exactly did you order? Was it .631" .2 lead? I'm still trying to decide on my lead screws. Either 1/2" 10 5start with dumpster nuts and pillow/flange bearings or a ballscrew from Reid. ANY suggestions would be appreciated : ) Which would have better accuracy.
I'm in the process of obtaining some thk linear guides and a @ 14" ballscrew for my z-axis. And i'm still using the 60" thk linear dovetail guides for the long axis.
One more question...would i be ok to use an unsupported 30mm hardened shaft (the picture above) as the gantry axis.
  #14   Ban this user!
Old 03-17-2008, 06:46 PM
Eurisko is on a distinguished road
Hi Tommy,
Yes, my Nook ballscrew arrived within a few days of placing the order.
It is a .631 dia, .200 lead. 48 inches long.
Here's the link:
Nook .631-.200 ballscrew
Haven't had a chance to play with it yet. I'll probably save it for my next (larger) router.
The Reid rolled ballscrew's lead tolerance is +-.004 per foot.
Reid precision acme threaded rod (single start) is rated at +-.003 per foot.
I don't know the specs on the multiple start acme rod, but I doubt that it will be as accurate as the precision acme or rolled ballscrew.
I would try it unsupported BUT give myself the option of installing full supports later if necessary. It would be interesting to measure the difference in rigidity...
Diplomacy is the art of saying "Nice doggie" until you can find a rock. - Will Rogers
  #15   Ban this user!
Old 03-19-2008, 06:35 PM
Thanks eurisko for the info...I guess the ballscrew would lend itself to being more efficient than the acme screw then? I feel that the accuracy is close enough to being the same where it wouldn't matter. How fast would the ballscrew push the axis? I know that the acme 10 5 start could push them at around 150-250ipm from what i've heard, with the correct motor/voltage setup. Is this doable with the ballscrew? I'm wanting to achieve around 200-300ipm, so whatever it takes.
Old 03-19-2008, 09:03 PM
ger21's Avatar
First, you need to check the critical speed for the distance of the screw and see if you can spin it at 1000-1500rpm. And more importantly, how much torque will your steppers have at 1000-1500rpm. I'm going to guess and say very little.
Planning a 4x4 Oakley1975 DIY-CNC Router Table Machines 11 01-01-2008 02:21 PM
Trajectory planning of EMC 2.0 Hebert LinuxCNC (formerly EMC2) 1 10-16-2006 12:12 PM
can someone double-check? (powersupply) anthony Gecko Drives 1 05-09-2005 03:46 PM
need help planning russell DIY-CNC Router Table Machines 14 03-18-2005 08:18 AM
Too much planning? Hobbiest DIY-CNC Router Table Machines 7 04-26-2004 08:05 PM
