After lurking for some time, absorbing as much information as I can, I have begun a 24"x24"x6" 3 axis CNC router. As this is my first build I am going to buy a 3 axis controller/stepper complete kit for the electronics. I'm not sure which one at this time, but that is my intent. It will have a moving gantry and stationary table. The X+Y will be skate bearing and the Z will be a linear bearing removed from an old color printer. (Which also had a decent stepper that might be used on the Z). I am an artist and this machine will just be the first of several. I am hoping to eventually build a 4'x8'x4' 5 or 6 axis machine to take my virtual 3d work and create actual physical objects. This small first one is mostly about teaching myself how to build and use one. I'm not worried too much about resolution, though i still want it to be decent. The frame/table/gantry will all be square tubular steel and a steel plate top for the table. (All of the steel is essentially free, leftover from a previous project).The frame will also act as the guideway/rails for the x+y. This being my first machine I am VERY open to advice, especially regarding the electronics. I have an old laptop that I am probably going to use and several dremels. Is there any reason not to use these for my first machine? I am trying to keep the cost pretty low. So let's see. I am currently on the market looking for: 2-3 stepper motors 3 axis controller boards 1 driver 1 power supply for steppers (Or a complete 3 axis electronics kit) And about 60 skate bearings Anything I am missing? Anything else I am missing? |
| Well for an easy router I would check out www.buildyourcnc.com I was going to build one based off of that, but I got a welder. I have some motors if you are interested, i could cut you a deal. |
| As for my router plan, I've got a bunch of sketches done, but will have the base table welded up by sunday and photos to follow. I just bought 40 skate bearings off ebay for $23 shipped. I already have 16 of the same bearings so I hope to have enough. Let's see what else... Trying to decide if I should start the Z axis or the Y axis after I weld the table together. My design is based on this machine, with a few modifications. |
| pm sent. A tip on the skate bearings, if you need a little more clearance you can grind the point of the angle off. You can grind it a good bit and still have plenty of metal left for stregnth. Also make sure that you get the bearings the same distance out from the center or they will be slanted in some. |
| I recieved my steppers in the mail from "thegimpster" Thanks, very much. I have another 70oz stepper as well. Between the four I bought and the little guy I am planning this machine as initialy a 3axis that i will use to build the 4th and 5th axis bits with. The bearings also arrived. The table top and frame rails are within 1mm of being "flat". I have heard mention of self leveling epoxy, anyone use this? how effective is it? In all honestly this is an acceptable deviation for my use for this machine, but if it is reasonably easy and cheap I'd like to increase it's precision. On welding the top to the top rails we clamped the bejebus out of it, and spot welded first and moved about the perimeter rather than following the edge. Anyways I'll be posting a drawing here shortly. |
#11
especially since it's so high. Think about putting walls on the sides of the table to run the horizontal part of the gantry on without having to move those big vertical members. The Mechmate design works that way, and it seems like a good idea to me... Andrew Werby www.computersculpture.com |
#12
I've worked a bunch with epoxy on MDF. If you want to seal your mdf it's not a bad idea so moisture does not warp you machine. But if you want to coat the top with a thin layer if may not be level enough. I would simply seal it. Let the epoxy wet out. It will also strengthen the mdf |
| Tags |
| 1st machine, 3 axis, build log |
| Newbie - To build or not to build Router/Plasma Table | dfranks | CNC Plasma and Waterjet Machines | 10 | 04-08-2011 12:16 AM |
| Router Using 3/4" MDF (first router build) | eguy208 | CNC Wood Router Project Log | 33 | 04-11-2008 11:33 AM |
| YET ANOTHER MDF ROUTER (UK BUILD) | Gfowa | Open Source CNC Machine Designs | 44 | 04-07-2008 04:33 PM |
| Help Want To Build A 4 Axis Router 60*144*22 | CETICARS | DIY-CNC Router Table Machines | 1 | 01-30-2006 03:03 PM |
