  #73
Old 04-19-2008, 09:29 AM
Mr.Chips's Avatar
Gold Member
Mr.Chips is on a distinguished road
Originally Posted by jeffmorris View Post
I think that if the CNC machine was built following the plans from Solsylva, it was built to sit on door, floor, etc, and rout on door, floor, etc. Do I have to raise the CNC machine 1-1/2 inches so that I rout wood that's placed on its base?
How about putting something under each leg to raise the entire machine?
  #74   Ban this user!
Old 04-19-2008, 10:27 AM
jeffmorris is on a distinguished road
I'm going to raise the entire machine using some pieces of wood.
  #75   Ban this user!
Old 04-21-2008, 05:03 PM
I raised the entire machine 2-1/2 inches so that the Z-Axis can have full travel. I used pieces of plywood glued together and pieces of steel bed mattress frame. I still have problems with limit switches. I checked wires and limit switches a million times and I can't get the limit switches to work correctly.
  #76   Ban this user!
Old 04-22-2008, 02:52 PM
I made two signs today. First one was good. Second sign was not good because the CNC machine didn't work properly or there's bugs in the G-Code program that was generated by Cut2D program. How do I test G-Code programs before I run the CNC machine? I know that I can put Mach3 program in off-line mode to test G-Code programs but what if something's wrong with the machine? I'm not sure if I can use computer cables between the enclosure containing the electronics and the home/limit switches. Computer cables are usually shielded. I already have shielded cables between enclosure and stepper motors. On another thread on this forum, someone was having problems with the home/limit switches and someone else suggested that he set the debounce parameters in Mach3 program. Link to thread: http://www.cnczone.com/forums/showthread.php?t=56869
Newbie - To build or not to build Router/Plasma Table dfranks CNC Plasma and Waterjet Machines 10 04-07-2011 11:16 PM
Router Using 3/4" MDF (first router build) eguy208 CNC Wood Router Project Log 33 04-11-2008 10:33 AM
1st cnc router build ajl6549 DIY-CNC Router Table Machines 1 11-02-2006 11:47 AM
I want to build/buy a cnc router bp092 DIY-CNC Router Table Machines 8 10-27-2006 08:39 PM
