  #25
Old 05-08-2008, 05:59 PM
KTP KTP is offline
Gold Member
KTP is on a distinguished road
I bought this one on ebay (nobody bid on it, works perfect):
http://cgi.ebay.com/API-Getty-servo-...QQcmdZViewItem
But you can use a wide range of brushless servos. This one runs quite smooth on a trapezoidal amp. You can get those on ebay also...I have gotten them as cheap as $25 each. You can then set the amp up in velocity or torque mode and use a simple trimpot to adjust speed. Personally, I am going to reprogram one of my Pixie boards to generate precision speeds as directed from Mach3, but that is overkill for most people. I also might try and use the spindle in some sort of rigid tapping arrangement since it will have such nice control.
Upgraded to Real spindle So Porter Cable is For Sale wcarrothers1 DIY-CNC Router Table Machines 23 01-22-2008 06:20 PM
Porter Cable 690 Rebuild Kit anoel Wood Working Tooling 2 06-16-2007 01:01 AM
Porter Cable 520 Smackre DIY-CNC Router Table Machines 0 08-23-2006 02:41 PM
Porter Cable 7518 for $250 ger21 DIY-CNC Router Table Machines 6 03-31-2005 11:45 AM
Porter cable spindle noise reduction or alternative? paulr4 DIY-CNC Router Table Machines 6 03-26-2005 12:56 PM
