| UHMW is expensive but this must be a thick piece if 8 square feet is that price; $562.50 a square foot does seem a bit steep.
| Why do you want a UHMW table? If you're trying to scale up a small machine and use the same materials, it may not work very well at the larger size.
because I want to use it for ICE machining and I heard UHMW works well with sticking to the ICE with a squirt bottle... |
| The cure time and rarity of large pieces in manufacturing seems to me to be the reason for the price jump. PVC pipe is cheap and pentiful, 6 inch rod isn't ![]() Have you thought of facing your exisiting table with a thin sheet of UHMV? Say a .125 of an inch or so? You'd get the non stick benefits without much compromise in work envelope (depending on how you fasten it). Mike Horne |
That is another problem is how to fasten the table to the metal base. I am thinking about using some sort of adhesive. I am not sure. For support though I am thinking about putting sheet metal underneath the plastic table. Then under the sheet metal maybe square tubing in an X-brace format. |
#10
I am going to use xylan 1424 on the steel. |
#11
I have heard that stone blood is an excellent alternative to xylan 1424
__________________ Drat, imperfection has finally stopped working!! |
#12
| And a few posts up you had this ; because I want to use it for ICE machining and I heard UHMW works well with sticking to the ICE with a squirt bottle... Do you mean you heard that ice sticks well to UHMW? That contradicts my experience, and makes you wonder why the bottom of snow skis are sometimes UHMW, so ice will not stick.
| Where to buy UHMW | Breaker | DIY-CNC Router Table Machines | 10 | 02-04-2008 10:41 AM |
| UHMW for ACME Nut? | Thinwater | Linear and Rotary Motion | 10 | 01-17-2008 11:57 AM |
| RFQ: UHMW Polyethylene Parts | lerman | Employment Opportunity | 6 | 01-23-2006 04:57 PM |
| UHMW Polyethylene | Eric Nelson | CNCzone Club House | 2 | 01-26-2005 05:15 PM |
| melting UHMW | Hobbiest | DIY-CNC Router Table Machines | 9 | 02-09-2004 04:42 PM |
