Old 02-14-2008, 04:39 AM
Designsync is on a distinguished road
Chatter vibration issues
I've just completed my home built MDF CNC router. My design is loosely based on 'www.buildyourcnc.com' design with a few changes here and there.
My first cut was into MDF and the vibration marks showed up immediately. I then tried a clear plastic cut (as attached) and still showed vibration.
This was cutting very slowly at around 8"/minute and I also tried upto 50"/minute which showed no difference. I varied the cutting speed from between 11,000-32,000rpm, nothing seemed to make any difference.
The distance between the router mount and the collet is 3", therefore router mount to tip of router bit is about 4". Is this distance too long? All axis movement are rock solid with no play at all.
The router cuts well when used freehand so that rules out any offset collet/router bit issues.
As you can see the sign looks OK from a distance but up close it's shocking. Has anyway resolved a similar issue. Any advise welcome.
Cheers
Iain
ID:	53267   Click image for larger version
Old 02-14-2008, 11:57 PM
cncspear is on a distinguished road
The pattern suggests a large oscillation which would indicate that your gantry is flexing. You might want to try lowering your acceleration ramp and your instantaneous start speed. Since you are starting and stopping in very short segments you are constantly accelerating and decelrating which upsets your gantry and causes it to oscillate. Machines without much rigidity and mass are very susceptible to flexing and vibrations.
As a test, plunge into a sacrificial piece of material and allow it to come to a complete stop at that depth. Then route a straight line from there for a good distance, say 20 inches. Take a look at the cut quality from start to finish of the line. You might notice that the oscillations or chattering is most pronounced at the very beginning of the cut and will diminish as it goes along the line. You may even notice some curviness at the beginning of the line which means the machine is flexing under the cutting forces.
For a sign building I would recommend you buy or build a more rigid machine to obtain cleaner cuts.
Gil
Old 02-15-2008, 06:10 AM
Shinosky is on a distinguished road
Designsync,
I am in the final stages of building my router and saw something similar to what you are experiencing. I use Mach3 and it turned out that CV (constant velocity) was turned off in the control. By re enabling it it smoothed out the movement
chatter using mach 2 jtriggs Mach Mill 5 01-10-2007 05:02 PM
boring bar chatter chipproducer General Metalwork Discussion 21 11-09-2006 11:23 AM
Chatter while cutting... saturnnights General Metal Working Machines 17 05-25-2006 11:31 PM
chatter problem bdrmachine General Metalwork Discussion 14 08-21-2005 07:24 PM
Chatter gabeless Hard and High Speed Machining 10 07-14-2005 12:09 PM
