Old 02-13-2008, 02:38 PM
MBG MBG is offline
MBG is on a distinguished road
I want a gantry type machine
I would like to build a gantry type milling machine.
I would like to do ice carvings.
Please if you can steer in me in the right direction please do so.
Old 02-13-2008, 02:43 PM
MBG MBG is offline
I am interested in making something like this. Just double the size.
Old 02-13-2008, 02:53 PM
MBG MBG is offline
Old 02-13-2008, 02:58 PM
MBG MBG is offline
I know this second one is 5 axis... I believe.. that would be harder to make huh?
Old 02-13-2008, 10:05 PM
andy_ck87028 is on a distinguished road
I would look at the different logs on this site and determine which best suits your needs.
I guess mdf is out for ice.
happy reading
Andy
Drat, imperfection has finally stopped working!!
Old 02-14-2008, 04:49 AM
MBG MBG is offline
happy reading
Andy
Well some use a MDF table and MOST use a UHMW table..
I want to go with the UHMW table...
So where do I get the parts? I want to go with Servo motors. Is there any blueprints on these things?
Old 02-15-2008, 08:39 AM
ahren's Avatar
ahren is on a distinguished road
A good approach for "bolt together" machines is aluminum extrusion -- look for various 8020 builds on this site. I sell a set of parts for use in building machines from extrusion. Alternatively, you could go for a kit from Joe -- see the various machines in the Joes2006 forum. Hope that's helpful.
Ahren
www.cncrouterparts.com
Old 02-15-2008, 11:38 AM
MBG MBG is offline
Ahren
I don't need a "bolt together" machine. I have a welder and access to a machine shop.
Old 02-15-2008, 11:23 PM
rlrhett is on a distinguished road
Then you are well ahead of many on this site. Again, if you take some time and read the post for various machines you should be able to get an idea of what is currently being done. Since you can weld, look at other builds using steel frames.
If you come back with specific questions after doing some initial reading on your own, you will probably get more helpful answers.
Old 02-16-2008, 11:08 AM
MBG MBG is offline
I have an idea on the machine and how I want it designed.
The problem/question I can't figure out is how to get the linear ways going. How to set them up and what not.
What are the types of ways you can get?
Robotic Plasma table instead of a gantry type? Hi-Vac CNC Plasma and Waterjet Machines 26 09-28-2009 01:58 AM
What type of machine BallisticFab General Metal Working Machines 1 12-14-2007 09:02 PM
Gantry type.CNC Mill dex918 Linear and Rotary Motion 0 08-22-2007 09:44 AM
Karbunkles 1st Gantry Machine karbunkle1952 CNC Wood Router Project Log 29 04-02-2006 09:56 PM
Gantry Machine Problem Alex S.A General Metalwork Discussion 2 09-02-2005 02:36 PM
