  #13
Old 02-14-2008, 03:24 PM
lovebugjunkie's Avatar
Gold Member
lovebugjunkie is on a distinguished road
Would be interested in the part numbers and source you use when you replace the pulley and belt. I agree the 0-ring belt looks to be the only thing that might cause problems.
jacek, You can see a close up pic of the 0-ring and motor Wolfgang provided here.
http://romaxxcnc.proboards59.com/ind...ead=1202506261
george
  #14   Ban this user!
Old 02-14-2008, 09:54 PM
wcarrothers1 is on a distinguished road
bbman.com was were I got the pulley. Was the only place that I could find with real small pulley's and metric bores (seeing the motor was from china of course out of a cheep sewing machine it had a 6mm shaft)..
bbman was great to work and very responsive. ..
b./
Wolfgang Engineering TB-350 spindle review Rhodan CNCzone Club House 8 10-26-2009 12:44 PM
Sweo spindle drive? new mill dead spindle Shizzlemah Fadal 13 12-18-2008 11:11 AM
interact 4 spindle drive won't turn on spindle 0041601 Bridgeport and Hardinge Mills 7 06-23-2008 05:51 PM
Lathe spindle bearings and spindle material mackeym Linear and Rotary Motion 1 08-11-2007 10:53 AM
Just had my spindle reground by Spindle Grinding Service! Edster Fadal 30 06-16-2006 10:48 PM
