Old 02-13-2008, 01:11 AM
LazyMan is on a distinguished road
5/8 Ballscrew Critical speed
Im trying to pick a screw for a machine and im stumped. I used nooks critical speed calculator and with a .5" root dimater and 48" from bearings it will give 372rpm. That seems low as this would allow for a max speed of 75 IPM with a .2 lead. I have read other posts of people running 5/8 screws at 800RPM. What am I missing here?
EDIT
Oops, I did not have the correct fixity selecte. I should be able to get around 1000rpm with a 48" screw. Does this seem like a realistic figure?
Old 02-13-2008, 06:06 AM
fseger is on a distinguished road
your didn't specify the length of screw. But for about 4' that seems right. On my DIY, I have 5/8" x .2 roton ballscrews about 54" between bearings. I don't have the "proper" setup with thrust bearings, just some needle bearings and radial bearings put together temporarily. I can move mine machine about 150-200 IPM before they start to whip. As you move closer to the center of travel you can move faster.
More Speed needed. Bigger Stepper or increase Ballscrew Pitch ? Joey Stepper Motors and Drives 12 11-30-2007 02:07 PM
Another which is better R&P,Ground ballscrew,rolled ballscrew,Acme,beltdrive etc.thre lgalla Linear and Rotary Motion 10 01-16-2007 11:27 AM
Pitch / speed / accuracy ? ballscrew m!ni DIY-CNC Router Table Machines 3 10-20-2006 10:08 AM
BPSeriesI / Centroid control- Spindle speed all out of whack with speed dial? peter.blais Bridgeport and Hardinge Mills 9 08-08-2006 03:29 AM
min speed exceeds max speed for axis "x"? ljoe1969 TurboCNC 4 01-19-2004 07:49 AM
