Old 02-12-2008, 06:32 PM
dikymon is on a distinguished road
Steel frame: welding or bond'n bolt?
Hello everyone
Long time lurker, finally started planning my first machine.
I plan to make a sturdy steel frame machine, and am currently doing some preliminary designing. I would like some input so i can better decide on the assembly method ill use. I have scoured the net and cnczone but haven't really found anything that would help me decide.
Choices are either welding or bond'n bolt with something like JD-weld.
My initial thought was to bond and bolt the frame together (which can be seen from the pictures attached), but how does this method compare to welding in an application such as this, where deformation is very unwelcome. This drawback is the main reason I shy from welding it together.
Question is: Can i bond'n bolt with success or would you recommend i attempt to weld it.
The images are very young, but i hope you can tell whats what anyway. It's kind of a hybrid machine, x-axis rides on top of the end "bridges" instead of a gantry.
The square tubings are is 80mm x 80mm (3.3in x 3.3in) and 6mm (0.25in) thick. Bolts are M10's 10mm (0.412in)
Dimensions of the frame are 1100mm (45.27in) long, 710mm (29.22in) wide and
580mm (23.9in) high.
Name:	machine v0.04 - bottom view.jpg‎
ID:	53141   Click image for larger version
Name:	machine v0.04 - bottom view (partially exploded).jpg‎
ID:	53142   Click image for larger version
Name:	machine v0.04 - side view.jpg‎
ID:	53143   Click image for larger version
Name:	machine v0.04 - side view (partially exploded).jpg‎
Old 02-12-2008, 06:56 PM
ger21's Avatar
You might want to spend some time reading this.
http://www.oneoceankayaks.com/madvac/madvac_index.htm
Old 02-13-2008, 01:45 AM
andy_ck87028 is on a distinguished road
I started bolting; then I thought about bonding and bolting vs welding.
I bought a cheap arc welder and haven't looked back.
Welding is great fun....
just keep your metal min 3mm thick.
Have fun
Andy
Drat, imperfection has finally stopped working!!
My Steel Frame Router epineh CNC Wood Router Project Log 484 07-05-2009 09:27 PM
TIG welding Steel/Iron welding with Argon? Rich05 Welding, Brazing, Soldering, Sealing 9 12-01-2007 07:11 PM
My 2nd Steel Frame Router epineh CNC Wood Router Project Log 12 07-12-2007 02:35 AM
Welding aerostar frame dmcenteer General Metalwork Discussion 3 09-24-2006 02:47 PM
Steel square tubing for frame samualt DIY-CNC Router Table Machines 10 08-20-2005 08:44 AM
