Hey guys, I just purchased a new 3 axis 2 phase driver and when i hook it up it doesnt work. I used the correct voltage for the driver. I installed mach3 using windows XP and the installed driver correctly but still cant get it to work. ![]() is there anyway i can test the printer port pins from to computer for a signal? or anything else i can do? Any thoughts? Thanks |
On the board you could measure if there's voltage going to the motor (this is probably the first thing you should do). If you're not getting any (which seems likely), and you feel comfortable opening up the driver, try testing different points on the board, namely the output of the driver's main chip. Also, do you smell anything burning? A weird stench of sorts? If so, say good bye to your driver, that means something fried a chip. |
| Give us some details on your 3 axis board, then maybe we can help....
__________________ Phil, Still too many interests, too many projects, and not enough time!!!!!!!! Vist my websites - http://pminmo.com & http://millpcbs.com |
| I am wired directly to the parallel port, also when i check the voltage going to the motor its constant voltage, it doesn't change when i have mach3 running. this weekend i will check the pins on the pc. also here are some specs on the 3 axis driver: * Resolution: Full Step,1/2,1/4,1/8. * Support two phase 4wire, 6wire 8wire stepping motor. * Compatible with many CNC software such as Mach, KCAM, TouboCNC, etc * Max 2.5A@36V 90W per axis. * Built in Manual Control Function for position adjustment. * Built in Restriction Bit interface for X-Y-Z axis. * Built in 1/2 current control interface for long time running, protect motor from overheating, enable via jumper. i am using motors from an old panasonic dot matrix printer. from my testing i found them to be 2 phase unipolar motors. thanks. |
| So it's a bipolar driver, what other informaion? If your unipolar motors are 5 wire motors it won't work for them.
| Boxford 280 Turnmaster wont work | flannman | Machine Problems, Solutions , Wireless DNC, serial port | 0 | 11-18-2007 04:12 AM |
| single axis driver and a b.o.b.,or multi-axis driver board | .xXACEXx. | Stepper Motors and Drives | 3 | 07-02-2007 11:13 PM |
| Why wont this work????? | epineh | General Electronics Discussion | 7 | 03-18-2007 12:44 AM |
| just a program that wont work | kangarabbit | G-Code Programing | 13 | 09-02-2006 09:38 PM |
| Syntax or just wont work??? | murphy625 | CamSoft Products | 1 | 04-05-2005 07:16 PM |
