Old 02-09-2008, 09:30 PM
rodjava is on a distinguished road
I need your thoughts on using 3 linear bearing for the Y axis cnc router
If I were to use only 3 linear bearing for my Y axis, what would be the best configuration? One on top, two on bottom? Or vise versa. I can't think of a reason why one is better than the other.
I only have 3 linear bearings which rules out other options.
BTW, I'm building a Data cut hybrid.
Thank you in advance.
Rod
San Francisco
Old 02-09-2008, 09:54 PM
LeeWay's Avatar
LeeWay is on a distinguished road
It might depend on your Z axis design, but like you have them looks good to me.
It might make a difference with twisting forces while cutting, so I would say that the way you have them is the most logical.
Lee
Old 02-10-2008, 09:51 AM
Oldmanandhistoy is on a distinguished road
Totally agree
Old 02-10-2008, 10:06 AM
The most important thing is keep the two that are on the same rail as widely separated as possible. Make sure that when your Y axis travels full distance each direction that the bearings trucks do reach the end of the ways.
Old 02-10-2008, 10:07 AM
Switcher's Avatar
Moderator
Switcher is on a distinguished road
The way you have them setup, looks good to me, also.
Free DXF Files - Vectorink.com - myDXF.blogspot.com
Old 02-10-2008, 10:12 AM
Thanks for you help
Thank you to everybody who responded.
I'll keep it like it's pictured. I thought that there was some type of mysterious force to consider. I don't have to worry about flex because of the 25mm bearings and all the 1" A/L which makes up the gantry.
Rod
Old 02-10-2008, 10:31 AM
A very good point to keep in mind; have you worked out your Z axis lay out?
These bearing systems can take very large loads and guessing the size of those rails and trucks from the picture they would probable be more ridged than you need, unless you are doing some seriously heavy cutting. So IMHO having the bottom trucks almost touching will be fine to maximise Y axis movement.
What do you other guys think?
What are you planning to cut, how heavy do you want to cut and what spindle do you plan to use?
If you are confident with your Y and Z design please just ignore this post
Old 02-10-2008, 11:48 AM
Here is pic of my gantry. Made mostly of 1" thick tool plate A/L. I'm building it to cut mostly A/L and mild steel. It's a data cut cnc router design which I "Pimped out"
THK HSR 35 rails and bearings for the X. THK HSR 25 rails and bearing for the Y & Z. Precision rolled 25mm ball screws for both X & Y and 15mm precision ground screws for the Z. Actual cutting area is 28"x48"
This is a picture before I machined and installed the Y ball screw. I had to add 1" risers to the Y rails to accommodate the large 25mm screws and the block mounted to the nut.
This a picture after the mod. I still have to machine the Z screws down to size and install them on the 1" plate the spindle will mount to.
Old 02-10-2008, 01:04 PM
Cartierusm is on a distinguished road
Hey how's it going. This is Carter, we emailed each other back and forth from Craigslist a while ago. Looks like yours is coming along. I got mine finished about 6 months ago, it's wicked fun. Let me know if you need any help. I can make parts on my CNC or my bridgeport.
Old 02-10-2008, 01:19 PM
Carter,
Good to hear from you.
My build is taking a while. 75% completed. Still have to search for servos and then the electronics.
Where did you say you live? I'm in the city. When it comes to the electronics, I'm a little lost. Might need your help then.
Building is no problem. I have a BP too.
Rod
  #11   Ban this user!
Old 02-10-2008, 05:29 PM
Aluminium and mild steel, that’s some serious work you have planned, will be interested to see how she performs once complete. Obviously the ballscrews and linear rails are up to the intended task so it will come down the rigidity of machine frame.
Wish I had a BP
  #12   Ban this user!
Old 02-10-2008, 06:08 PM
Oldman, if you have the space it's really not that big of a deal if you have patients. Most BP go for $3000 and up but every single day companies and people moving let them go for $1000. If you have the cash ready you should be able to pick one up. Just be patient. Depending on where you live there are a lot of companies who sell them on Ebay and craigslist. Opps I just realized you are one of those british folks...I love London, where are you located?
Rod, I'm in Burlingame. No problem if you need help just ask PM if you want my phone number. The electronics at first were a big problem deciphering all the crap, especially since I didn't know what step and dir were, but now it's actually very simple, very hard to screw up if you know what you're doing. I have a lot of experience at mods and upgrades as I had a hell of a time with Keling.
Z axis linear bearings for MDF router martinw Linear and Rotary Motion 25 10-28-2007 04:18 PM
Z axis THK flat or Round linear bearing flash319 Linear and Rotary Motion 6 03-26-2007 02:26 AM
Linear slides for z axis router kent chasson Linear and Rotary Motion 4 10-26-2005 12:17 AM
Linear Bearing for Router Table PaulH Linear and Rotary Motion 16 07-22-2005 10:27 PM
Best linear bearing system for a dusty router ddgman2001 DIY-CNC Router Table Machines 6 05-29-2004 07:19 AM
