Old 02-08-2008, 09:05 AM
axkiker is on a distinguished road
linear rails VS shafts
Hey all what do you consider to be the stronger more ridged design. The linear rails or the shafts.
I will be building a machine designed to mill aluminum so strength is of the upmost importance. I cant have alot of flex or bearing play. I see the linear rails are pretty pricy so im guessing they must be the better of the 2. However I have no experience.
what are your ideas
thanks
Old 02-08-2008, 09:36 AM
DareBee's Avatar
Monkeywrench Technician
DareBee is on a distinguished road
Your assumtion is correct.
Fully supported using heavy stable cast is best (well...epoxy granite is best...but).
Next best is HEAVY steel construction, stress relieving (normalizing) is important.
www.integratedmechanical.ca
linear rails lgalla Linear and Rotary Motion 5 02-08-2008 04:35 PM
Linear Shafts... WilliamD Linear and Rotary Motion 1 01-19-2006 12:23 PM
Linear bearing spacing & Sizing linear rails? fyffe555 DIY-CNC Router Table Machines 3 12-07-2004 01:09 PM
Shafts or rails? sjmarsha DIY-CNC Router Table Machines 5 06-30-2004 06:49 AM
What type of steel for linear shafts can I machine? cbcnc DIY-CNC Router Table Machines 0 04-14-2004 12:57 AM
