Old 07-16-2004, 09:15 PM
jjwl89 is on a distinguished road
Ball Screw Question
I was wondering how much accuracy is possible with rolled 5/8" ballscrews? Could they be accurate to .005"?
Old 07-16-2004, 11:57 PM
sendkeys is on a distinguished road
Old 07-17-2004, 12:49 AM
starCNC is on a distinguished road
[i]
p.s might think about making your own "preloaded nuts" with two cheaper normal nuts. [/B]
Can you show me how to make the preloaded?
Old 07-17-2004, 07:13 AM
Old 07-17-2004, 09:13 AM
replicapro is on a distinguished road
I got my ball scews from http://www.mcmaster.com/ for $1.09 per inch
I used their ball nuts $21.04 each to make a loaded ball nut using Dan's method from Camtronics.
Instead of turning down the ball nuts he added a coupler
Then simply put it on the end of the ball screw
Old 07-17-2004, 10:15 AM
Chagrin is on a distinguished road
That requires a bit of magic to internally thread those couplers to match the ballscrew, doesn't it?
Old 07-17-2004, 10:29 AM
How about ballscrews from Roton. Has any one used these before? How do they preform? http://roton.com/web/balls.jsp
Old 07-17-2004, 04:53 PM
No Dan said to use set screws
My thought is to use a shear pin.
Old 07-17-2004, 05:27 PM
Bubba's Avatar
Bubba is on a distinguished road
I am presently seting up a system using the ball screws from Roton. I have received them and they loolk good. The packaging was supurb and the e-mails that I have had with them has given good me a good feeling. they have been very responsive to my questions and the order was made and recieved in good time.
Right now, I am still making pieces parts for the assembly and will probably start on the actual machining of the lead screw next week/
Bubba
Art
Old 07-17-2004, 05:54 PM
IJ. IJ. is offline
Gold Member
IJ. is on a distinguished road
How are you going to drill through the ballscrew?
  #11   Ban this user!
Old 07-17-2004, 06:06 PM
The shear pin is an oval bar that gets inserted into a milled out section
Old 07-17-2004, 06:11 PM
IJ. IJ. is offline
Gold Member
Ahh with ya now!!
I was thinking a shear pin across the ballscrew and couldn't imagine how to break the surface to drill the hole!
Ball Screw Identification BeerFizz Benchtop Machines 2 04-07-2005 10:28 AM
Ball Screw Mounting Question. Willyb General Metal Working Machines 11 01-18-2005 12:02 PM
Mini Mill 5/8 Ball Screw conversion Question rustyolddo Benchtop Machines 3 12-12-2004 12:24 AM
Need help with Ball Screw Choice samualt DIY-CNC Router Table Machines 5 09-06-2004 07:02 AM
Ball screw size/pitch? jakk100 DIY-CNC Router Table Machines 7 06-18-2003 10:21 AM
