Old 07-16-2004, 12:13 PM
Binow is on a distinguished road
Where is a good place to start?
I would like to learn about the DIY side of cnc routing. I currently oversee an area at work that has two cnc routers depaneling PCB’s, which are built by ATI and cost about 80k a piece. As capacity increases so will the need for at least another machine or two. I'd like to have the option to maybe go a cheaper route and build a DIY one instead. These are strictly for cutting tabs on PCB’s to take them out of a paneled form. We don't need anything near as heavy duty as we currently use. Any suggestions on where I should look to start learning about what I will need and how to assemble all the pieces? Obviously reading here is a good start but any other info/suggestions would be greatly appreciated.
Old 07-16-2004, 02:52 PM
jeffs555's Avatar
jeffs555 is on a distinguished road
First off, I am a relative novice at CNC, but not at DIY. From my experience, I would not even consider a DIY machine for what you have in mind. DIY is great for home projects or start-up businesses where you have more time than money, but in a going concern where up-time is important, and labor actually costs money, DIY is rarely the way to go, unless it is something you can't get commercially.
I do agree that 80k machines are probably overkill for what you are doing. How big are the panels? How many boards are cut from each panel, and how big are the tabs, ie how much cutting do you have to do? There is probably something available commercially to do the job for a lot less than 80k.
Ballscrew Basics Swede Linear and Rotary Motion 101 04-16-2012 08:09 PM
Where is a good place to purchase IC’s in the UK? bob a job General Electronics Discussion 2 01-18-2005 05:06 AM
Please help find good CNC... dino-new General Metalwork Discussion 11 01-13-2005 05:24 AM
IS Bobcad V19 a good program to start Biggermens General CAM Discussion 15 10-29-2004 09:46 PM
ware is a good place to buy stepper motors ? Biggermens Stepper Motors and Drives 2 10-28-2004 07:26 PM
