Old 01-30-2008, 07:21 PM
carsonau is on a distinguished road
Suggestion for a CNC router!
I am very lost with my CNC project atm! It is very difficult/expensive to source out parts in Australia!
However, I have all the electronics and stepper motors from HobbyCNC all soldered and tested! So that's a start.
I want to mill wood, aluminium and maybe some copper. It doesn't have to be fast, it can do 0.01mm passes for all I care (but will doing this have it's own issues)?
I've been looking at the http://cgi.ebay.com/WidgitMasters-NE...ayphotohosting
Widgetmaster kits....But they dont seem to be big enough. I want a router that is give or take 400mm by 400mm....but if i have no choice i a widgetmaster kit could do...
I really dont know!
Old 01-31-2008, 02:24 PM
ahren's Avatar
ahren is on a distinguished road
The approach you take will probably be dictated a lot by the following requirements:
-Work envelope
-Speed
-Cutting forces (a function of the tools you use, speed you want to cut at, and materials you want to cut)
-Accuracy
-Budget
If you can answer those questions, people will be able to make some better recommendations for you. There's a lot of good resources here on the zone who can help you out!
Ahren
www.cncrouterparts.com
Suggestion for my next pcb mill Aurbo DIY-CNC Router Table Machines 2 02-02-2008 10:43 AM
Router suggestion Toysrme DIY-CNC Router Table Machines 3 03-10-2007 07:42 AM
A suggestion shreifali General Metalwork Discussion 0 02-05-2007 08:44 PM
A suggestion and a thank you.. murphy625 Suggestions for the CNCzone.com site. 1 03-05-2005 07:02 PM
New guy and I need suggestion. dmgdesigns DIY-CNC Router Table Machines 7 01-31-2004 05:29 PM
