Old 01-30-2008, 09:49 AM
wcarrothers1 is on a distinguished road
Help- Source for small pulley
Hello..
I'm adapting a sewing machine motor to run one of those wolfgang Eng Spindles. The motor he sells isn't variable speed and the sewing machine motor is and has better torque/nice and quiet.
I'm looking for a pulley that would need a
6mm bore and maybe a 1.25" diameter. Could be flat or be for a small o ring type belt grove.
Just having trouble finding selections starting with the 6mm bore for the most part
Figured maybe Small parts inc or something might have something but there site is hard to navigate. Mcmaster does not really do metric from what I was able to look up.
Thanks in advanced.
Old 01-30-2008, 09:53 AM
widgitmaster's Avatar
Gold Member
widgitmaster is on a distinguished road
Try here!
https://www.smallparts.com/
They have a large assortment of gears, pullys and other odd stuff!
Eric
www.widgitmaster.com
It's not what you take away, it's what you are left with that counts!
Old 01-30-2008, 10:47 AM
Gold Member
Bill
SmallParts #IPD-20
It has a 1/2 ID which can be reduced with a bronze bushing
http://www.smallparts.com/products/descriptions/ipd.cfm
Widgit
Old 01-30-2008, 11:04 AM
Need something that can have a set screw for holding to the motor shaft..
Think I've found something on bbman.com but it's a timing pulley rather then just flat or 1 grove for a round o ring type belt.
Probably should just nuckle down on my lathe and make my self one up..hehe
b.
Old 01-30-2008, 11:08 AM
Actually a better idea is to get the timing belt a little large and turn out the ribs making my o-ring belt grove.. Hmm
b.
Pulley set theclive I.C. Engines 2 08-22-2007 10:56 AM
Source for small ISO toolholders cncuser1 CNC Tooling 3 01-18-2007 05:56 PM
small quantity plastic source? zcases Glass, Plastic and Stone 7 01-02-2007 11:20 AM
Found a good source for small stepper driver transformers! $3 25v 2a transformers. radicooldude General Electronics Discussion 3 05-02-2006 02:15 PM
small (<1amp) driver -- source? anthony Stepper Motors and Drives 1 06-09-2005 01:45 PM
