Old 01-29-2008, 01:12 AM
joe kilo is on a distinguished road
is this seem right, bearing contact
I think this contact surface is awfully sharp. I've set the holes up like joes and many others. Also tried various spacings all ride on bearing edge. I mocked one up at .625 in and the bearing rides flat but nuts hit top and won't nest. is everyone elses like this. here are two pics and you can see thanks joe.
Name:	jan 28 2008 110 [1024x768].JPG‎
ID:	51919   Click image for larger version
Name:	jan 28 2008 103 [1024x768].JPG‎
Old 01-29-2008, 01:30 AM
MrWild is on a distinguished road
I used longer bolts with washers stacked then a spacer nut. Works just fine. It looks like you are using the bearing height used for the 3/4" pipe, and not the right stack for the 1" pipe. There are two different spacer lengths. due to two different pipe diameters.
Angular Contact Bearing Confusion skipper Linear and Rotary Motion 9 11-08-2007 06:07 AM
Angular contact bearing question Rube Benchtop Machines 19 09-20-2007 11:14 AM
Tapered roller bearing vs. angular contact bearing boyvox Linear and Rotary Motion 12 01-25-2007 02:49 PM
Angular Contact bearing question sendkeys General Metal Working Machines 2 07-12-2004 06:45 PM
Angular Contact Ball Bearing ? sendkeys General Metal Working Machines 2 06-24-2004 02:06 PM
