So after I build my CNC, and want to start playing with the machine, on the cheap(software wise), this is what I would do. 1. Use one program like simple-g to build my files and then export to g-code. 2. the I use that g-code file and load it into something like mach3 which actually runs the CNC(motors). Am I getting this straight. Thanks! |
| Kind of. I'm not sure what simple-g is but here's the break down. Most people use a cad, drawing or cam program to design the part they are making. You could write your own g code to do what you want but if you're asking the questions you're asking I doubt you know g code...hell I don't know g code, I recognize basically what's going on...but I digress. Anyway alot of CAD programs have counterpart programs called CAM which actually write the g code. That makes a file and you load that into a program that actually controls the CNC machine, such as Mach. The way I go about it as I'm a noob as well is I either design the part in Artcam or draw it in Adobe Illustrator, make sure in illustrator you save it as version 8 or it will import very weird, then import it into artcam. Artcam has cad and cam built into one so it makes it very easy. Then I save the g code and open it up in mach 3. |
| Similar thread here. Several ways to do this pending your preference for CAD and willingness to spend $ for CAM. In all cases you will need control software such as Mach. http://www.cnczone.com/forums/showthread.php?t=50573 |
| As a newb, I had no idea what the flow was to get from a drawing to a finished file that would make the router cut something. I messed with emc under ubuntu, but I am more of a windows guy. Anyway, you can download Mach3 for free and run up to 500 lines of gcode. More than enought to get familiar with it. To turn a drawing into gcode, CamBam, free to use, works great and is a great learning tool. As far as converting a drawing, you can just create something simple like a circle in CamBam, do a pocket, do a toolpath, and export it to gcode, comes out WAY under 500 lines. This allows you to calibrate the cnc machine, which gets you familiar with Mach3, etc, etc. |
| Straight knurling ??? | turmite | General Metalwork Discussion | 5 | 09-11-2009 11:30 PM |
| straight crown molding | markos | CNC Wire Foam Cutter Machines | 3 | 10-30-2007 03:56 AM |
| Need a straight answer... | WilliamD | Mach Software (ArtSoft software) | 3 | 09-14-2006 05:18 PM |
| Cant get threaded rod straight. | Fodder1 | JGRO Router Table Design | 16 | 05-23-2006 10:44 PM |
| Hints on drilling straight?? | gtrdude | General Metal Working Machines | 5 | 08-10-2004 07:05 AM |
