Old 01-21-2008, 11:49 PM
cpcapace is on a distinguished road
Some help please. Just starting. Newbie
I purchased some cnc plans. It's for a small table, but it should suffice my current needs. Here are my questions, and any help would really be appreciated.
Here is the board I think I want to go with due to it's ease of use. The problem is, does anyone know what brand it is. Or is mechatronics the brand.
http://video.google.es/videoplay?docid=-5281796970250102073&q=3axisdrive
Second, what about a good affordable CNC program. Free or low cost. Just to give you an idea of what I need it to do.
Here is a 3d image of the design I need to have routed. The board will be saw cut, it's just the pocketing and holes I would need routed. The rought dimension of the board are 9' x 18"
http://www.clarkopace.com/images/cnccut.jpg
Thanks!
Old 01-22-2008, 07:21 AM
BobF is on a distinguished road
I used the hobbycnc board and motors for my build. It works well and has many users on this board, so it easy to find help if you need it.
I use and recommend VcarvePro. At first glance it looks expensive, but is well worth it.
Old 01-22-2008, 07:53 AM
Oldmanandhistoy is on a distinguished road
I would stick to well known brands of driver boards Hobbycnc, Xylotex and the like.
Software: Sheetcam low cost and ideal for the part you posted. www.sheetcam.com
John
Old 01-22-2008, 09:38 AM
jdell42 is on a distinguished road
I dont think mechatronics is the brand... I have looked at a lot of driver boards and I don't recongize that setup. Its running at 6A which interests me.. They also fail to show you the power supply setup in the video.
If you want a similar "easy" setup at 3A the HobbyCNC is the way to go.
Old 01-22-2008, 02:56 PM
_taz_ is on a distinguished road
the one in the video is a machatronics board.
I'm a noob at this stuff, but I try to stick with stuff the regulars use. (mostly cuz if I have a prob they've already seen it and know how to fix it)
Old 01-23-2008, 11:16 PM
Thanks!
Old 01-24-2008, 02:47 AM
Cartierusm is on a distinguished road
As far as a CNC program I've only used Mach 3. I know alot about computers and mechanics, but not a lot (until now) about cad/cam/cnc, and mach is real easy to use; has a ton of supporters out there and is cheap $150.
Old 01-24-2008, 02:55 AM
Khalid's Avatar
Khalid is on a distinguished road
Recommend Mach3+VCarvepro
Old 01-30-2009, 11:22 PM
shovelhead3d is on a distinguished road
Hi I just ordered the mechatronics 4axes and a 36v power supply.Over the last 3 or 4 months I've seen a lot of them go on e-bay. I'm new to the cnc world. I picked up an old pr cable sys ShopBot 4 or 5 months ago with no card,driver or pc. My work dropped down to very little. I had done some work in return of a Gecko G540, an I'm still waiting. So I got the mechatronics on e-bay just to get it to work. I hope to get it next week ,so I'll let you know.
help in starting chopper14 CNC Plasma and Waterjet Machines 25 07-29-2009 06:15 PM
starting out onya Australia, New Zealand Club house 0 12-20-2007 02:57 AM
Just Starting Out and Need Help bnoji General Metalwork Discussion 6 01-01-2007 12:27 PM
Starting from sub-zero eternauta3k JGRO Router Table Design 31 01-24-2006 08:55 AM
Please Help me starting right!!! CrazyRonny General Metal Working Machines 32 04-13-2004 10:50 PM
