I have been evaluating several CAM programs looking for a program that will let me ramp into/out of a profile tool path. Why don't most CAM packages allow you to do this? How is everyone else getting around this? I always see "don't plunge cut or you will shorten tool life" but I have yet to find a good way to router out parts from a sheet without plunging. Any suggestions or comments? Thanks in advance |
| Partsman, A couple of options, 1) Draw your own ramp into the existing profile.. 2) Pre-drill a hole location outside or inside the profile that allows you to plunge into the pre-drilled hole and then proceed with the horizontal cut in x or y. I have wondered why the no ramp myself in my own cam software. Ken |
| A good machining practice would be to Pre-drill a hole If you have a 3/4 end mill use a 7/8 spade drill or indexable, Most of your higher end Cad/Cam programs such as Catia and Unigraphics will have Ramp in/Ramp Out Geometry, You can control the Direction, Length and Feed. |
| Thank you everyone for all of your suggestons. I had just tried all of your suggestions to see which would be best when I got a call from VisualMill. The new version 6.0 will ramp into profiles!!!! AND it will be available as RhinoCam V2 due out soon! I already use Rhino to do all of my CAD work so I think I found exactly what I needed. Thanks again for all of your suggestions. Aaron |
| vcarve allows ramping, I don't recommend plunging down a z at all, especially not with spiral cutters, I always ramp when I can.. it extends the life of the tool and spindle significantly and really doesn't add a lot of time onto toolpaths |
| Another option to this that I use at the machine is to write a little program at the machine using the current tool that you will be machining with and has less tool pressure then just ramping from point a to b. It is a simple helical mill that is used with a M97 subprogram call up. example: % G0G20G40G80G90 M6T1 G0G90G54X0Y0S3000M3 G43H1Z2./M8 Z.1 G1Z0F20. M97P1000 (THIS CAN BE CALLED UP MANY TIMES FOR THE SAME PATH AND WITH OUT CHANGING PROGRAMS) (CONTINUE AT PROGRAM DEPTH) G0Z2.M9 G91G28Y0Z0 M30 O1000 G91X.0625 G3I-.0625Z-.01L10(ADJUST AS NEED THIS WOULD BE .100 DEEP) I-.0625 G1X-.0625 G90 M99 % |
| ramping on a arc | binzer | GibbsCAM | 7 | 06-10-2008 08:38 PM |
| Need Advice For Ramping Angle | lerman | General Metalwork Discussion | 0 | 03-27-2005 12:49 PM |
| Ramping | pauls | BobCad-Cam | 1 | 03-04-2005 03:49 PM |
| Ramping example? | inthedark | G-Code Programing | 5 | 04-10-2004 08:53 AM |
| BobCAD; steps on ramping? | inthedark | BobCad-Cam | 18 | 04-07-2004 08:48 AM |
