Old 01-14-2008, 11:25 AM
rossmkly is on a distinguished road
Post Plotter Parts Survos Belts Screws Etc...
Has anyone used parts from a plotter to make a CNC router? I have an old Large Pen plotter and was wondering if I could use the survos and control boards or drivers from the plotter to drive the Survos on the CNC router?
Old 01-15-2008, 05:34 PM
johnmac's Avatar
johnmac is on a distinguished road
I just finished tearing an old E size (24x36 inch) pen plotter. The motors look too small. I don't see how the driver board could be used with G code. The pulleys look good, but the belts are old. Then there is only parts for 2 axis.
John
Old 01-16-2008, 06:50 AM
neilw20's Avatar
neilw20 is on a distinguished road
Cool Use for a plotter.
I am retrofitting an A2 Roland Plotter to be a pick and place SMD component machine complete with multi pickup tools and multiple parts carriers.
Most plotters are much to light and under powered to be used as a router.
I have to be careful that the parts attached to the carriage are VERY LIGHT,
and I am only placing parts that weigh milligrams. Inertia rules cos I want speed.
Hope to place 20 - 30 parts per minute. Better to be ambitious?
Super X3. 3600rpm. Three ways to fix things: The right way, the other way, and maybe your way, which is possibly a faster wrong way.
Old 01-17-2008, 02:54 PM
joecnc2006's Avatar
www.joescnc.com
joecnc2006 is on a distinguished road
John
24"x36" is D size paper.
Old 01-17-2008, 06:47 PM
neilw20's Avatar
Talking Still using the plotter electronics. No need for G-Code.
The plotter doesn't know the difference between a pen and a suction tube.
Just move to a position, pen down, release vacuum, pen up and go suck up another part. Component orientation and alignment mechanism at pickup station.
If it writes with solder paste instead of ink it won't be none the wiser either.
If one of the pens is a TV camera so be it.
Making full use of original DMPL/HPGL language through 1 serial port.
That leaves a parallel prot to manupulate the parts feeders etc.
Custom software in VB.
Only thing missing is the hot air gun 'PEN'. It might melt some of the plastic!
Need Digitizing for 4 parts and accompanying screws and pins theclive Employment Opportunity 8 05-10-2007 02:42 PM
FAQ's (Motion Transmission,Acme, Ball, Allthread Screws, Cogs, Belts, bearing, etc ) snooper Linear and Rotary Motion 13 02-28-2007 05:28 PM
Belts to replace long ball screws? What are your thoughts?? runinbymdnt Linear and Rotary Motion 11 02-17-2007 04:31 PM
FAQ's (Motion Transmission,Acme, Ball, Allthread Screws, Cogs, Belts, bearing, etc ) chuckknigh DIY-CNC Router Table Machines 44 12-31-2004 06:54 AM
FAQ's (Motion Transmission,Acme, Ball, Allthread Screws, Cogs, Belts, bearing, etc ) chuckknigh FAQ of CNC Machine building 0 04-28-2004 08:55 PM
