Old 01-08-2008, 07:33 PM
studysession is on a distinguished road
Need Help from the experts
Hi -
Attached is a pic of my machine. I cut a design into a piece of MDF and was happy with the results so went to Home Depot to get a board and try something other than MDF. I got the table top grade cut flat wood and cut a small 11.5x10 piece from it to cut a design. All went ok except for one thing.
Even though the MDF cut same depth all the way accross when testing it did not happen with this. The laft half has shallower cuts than the right half which leaves me to believe that the board is not square.
How do people compinsate for this?
Thanks -
SS
Please check out my CNC blog
http://cncinside.com
Old 01-08-2008, 08:00 PM
ger21's Avatar
Mill the board flat first.
bearing experts i need your help? MaxQ General Metalwork Discussion 3 06-22-2007 04:26 PM
Some basic questions for the experts jdell42 DIY-CNC Router Table Machines 7 08-16-2006 08:31 AM
Any AB PLC experts? jderou General Electronics Discussion 5 11-11-2005 07:14 PM
any pic experts? posix PIC Programing / Design 27 07-01-2005 02:27 AM
Question for you servo experts kevincnc DIY-CNC Router Table Machines 2 03-12-2004 02:07 PM
