Old 12-23-2007, 11:17 AM
studysession is on a distinguished road
8020 bearing help
I purchased 2 8020 bearings. They are very smooth when I do not attach anything to them. The attached picture shows the bearings and what I am trying to do. I attached a piece of wood where my Z-axis will mount to and then it hardly slides at all.
How does everyone get these things to slide easy when they are attaching their parts to them?
Hope I explained this well enough. I really want to use them and try something different. I have trollies with bearings but really want to get these to work and try them out for a while.
Many thanks for the help in advance and happy holidays.
Please check out my CNC blog
http://cncinside.com
Old 12-23-2007, 12:57 PM
ger21's Avatar
There's a reason you don't see anyone using those. To get them to work, you'll need to add two more, and locate them at least twice as far away from the two you have are apart. Otherwise they'll just keep binding.
Old 12-23-2007, 01:09 PM
Thanks -
Was hoping for simple answer and they would work.
Old 12-23-2007, 07:58 PM
Regnar's Avatar
Regnar is on a distinguished road
You need to make sure you upper and lower (Y axis I believe) is parrel. If the upper side is set back just alittle further than you lower side, when you tighten up the bolts you will be canting the bearing and cause binding.
You should also make sure your bearings are flat too. What I mean is that the side that you are attaching to the wood is flat. If it is cupped when you go to tighten the bolts it will pull the bearing in tighter and cause a simular effect. Hope this helps
Old 12-24-2007, 09:03 AM
GaryCorlew's Avatar
GaryCorlew is on a distinguished road
I tried the same road you are taking, I could not make them work unless they had a lot of play(slop) in them. I wish you luck, I ended up going with VXB linear bearings, much better! but still not as good as thk and those type but the price was right.
Old 12-24-2007, 09:12 AM
Thanks -
I have trollies and bearings. Just wanted to see if I could use the 8020 for this. Going back to my trollies and bearings. Thanks again for the input.
8020 hardware CRFultz 80/20, TSLOTS and other Aluminum Framing Systems 0 07-11-2007 03:33 AM
Tapered roller bearing vs. angular contact bearing boyvox Linear and Rotary Motion 12 01-25-2007 02:49 PM
Cutting 8020 dneisler DIY-CNC Router Table Machines 6 10-03-2005 08:24 AM
8020 cad drawing cnc2k General Metal Working Machines 1 08-10-2004 07:13 AM
