Old 06-29-2004, 05:59 PM
signIT is on a distinguished road
DXF or PLT files
Hi all,
I need some common connector dxf files for making mounting holes in front panels.
The dxf files I need is for XLR, D-Sub and other common audio connectors.
Glha
Old 07-01-2004, 04:57 PM
I have done it, I run the Front Panel Designer and copy the drawing, then I paste it in Corel Draw 11 save as DXF and open the file in a Auto Cad type of software just to check the measures back to Corel Draw and stretch to right measure then save as PLT.
It is easy and fast to use the Front Panel Designer as this program has a idiot safe way to place holes and the best of all it is a real freeware full function with precision http://www.schaeffer-apparatebau.de/English/index.htm
Guitar dxf files and fret calculator. ynneb Musical Instrument Design & Construction 5 06-15-2010 02:09 PM
dxf files or g-codes? mocnc DIY-CNC Router Table Machines 3 09-30-2004 08:41 PM
3D dxf files NeoMiller General CAM Discussion 6 11-06-2003 09:42 AM
DXF files mmjpotter General CAM Discussion 2 09-18-2003 11:51 AM
Dxf Files WOODKNACK General CAM Discussion 7 08-06-2003 04:05 PM
