Old 12-21-2007, 01:38 PM
rlrhett is on a distinguished road
Roller Chain?
I saw a show last night on the manufacturing of roller chains. It made me wonder if anyone has used roller chains and sprockets rather than rack and pinion, screws or timing belts. Can anyone point me to a discussion on the merits for a hobby cnc application?
Old 12-21-2007, 01:51 PM
dertsap's Avatar
Gold Member
dertsap is on a distinguished road
Use roller chain to move gantry.
A poet knows no boundary yet he is bound to the boundaries of ones own mind !! http://cnctoybox.org
Old 12-21-2007, 04:19 PM
Weldtutor's Avatar
Weldtutor is on a distinguished road
Originally Posted by rlrhett View Post
I saw a show..... It made me wonder if anyone has used roller chains and sprockets rather than rack and pinion, screws or timing belts.
Another link to a chain driven table that gives excellent results!
http://www.cnczone.com/forums/showthread.php?t=16634
Have fun reading.
Old 12-21-2007, 09:26 PM
dertsap's Avatar
Gold Member
steel cable may be a good and economical alternative , i was going to use chain on my router , i experimented a fair bit with it and i was quite pleased with the results . i ended up getting a wicked deal on some 10 start lead screws and crossed over to screws , ive used one screw/axis ,so what ive done to keep the gantry solid is added cable and pulleys on shafts at each end of the table (similar to a belt system), after looking at that i see no reason cable couldn t drive a system , once the cables are tightened up there is nothing within reason that will make them slip
simple basics is usually the most effective with most stuff , i think too much gets over engineered ,in the link i posted previously i loved the way Beetman changed peoples tunes with his system
Use roller chain to move gantry. Beetman05 CNC Plasma and Waterjet Machines 70 02-22-2009 03:06 PM
E Chain Bobbyr70 Linear and Rotary Motion 5 01-20-2008 06:09 PM
E-Chain Installation mcyr DIY-CNC Router Table Machines 3 11-08-2007 05:01 AM
E-chain JerryFlyGuy General Electronics Discussion 9 03-11-2006 11:12 AM
