Old 12-19-2007, 09:53 AM
NEATman is on a distinguished road
Cool Belt Drive Gantry with STATIONARY motors for X and Y Axes
http://www.atsautomation.com/automat...t_superbot.asp
Has anyone considered this type of architecture for a belt drive machine? It would seem to be ideal for a plasma cutter, Laser system or light-duty router.
The key feature of this patent is that the X and Y motors are mounted to the frame and both are statinary! Check out the picture. Also, look at the videos on ATS's website. These things are FAST!
Some of the advantages are no moving cables for the X or Y motors. I even have a concept for having a stationary Z axis motor. And a concept for increasing the performance of the X or Y axes during fast moves. Also, I would think that these would benefit from a crossed cable/belt design - like a car power window - to drive both sides of the gantry evenly and prevent binding and increase the squareness stiffness of the entire system.
I'm certainly going to keep this design in mind for future systems.
NEATman
Name:	Pat 5611248.jpg‎
Direct Drive Vs Belt Drive for a Mill/Drill Retrofit? pfeist General Metal Working Machines 11 02-13-2012 02:12 AM
Belt Drives on Axes? JMcDonald Benchtop Machines 11 09-30-2007 03:18 PM
X1 Belt Drive? Tag1260 Benchtop Machines 12 08-31-2007 05:38 PM
Error Axes Drive Fault on CHNC I asantos General CNC (Mill and Lathe) Control Software (NC) 5 03-12-2007 12:33 PM
How do you drive your gantry cnc nash Polls 5 12-07-2006 08:54 PM
