Hi, I recently completed my first router which I intend to use on wood and aluminum. I've adjusted my x and y axis to travel 1" within .001 on a dial indicator and to travel say 12" and return to the same spot. Today I tried to pocket a 4.25" circle, .25" deep using a .125 end mill taking .050" per pass. I noticed on the first pass that diagonally opposite 0,0 there was material left between each trip around the circle and the closer to 0,0 each trip around overlapped removing all the material. On each pass afterwards the circle would shift towards 0,0 maybe .020 or .030". Basically I'm getting a circle fatter at one side. Any suggestions on where to start with this would be appreciated. Thanks Bert |
| You could try cutting the same code at a very slow speed - as slow as you can wait for. If the error is the same, then it shouldn't be lost steps due to loss of torque.
| I did try it at very low speed. 2 ipm. I also tried it fast. Same thing. It does seem that it accumulates the more times around the circle. I'm wondering if my settings are a problem. Originally I had it set at 3200 steps/inch. When I jogged 1" I was actually getting something like .991 in one direction and .982 in the other. I adjusted my steps per inch upward on both so it jogged 1". They are slightly different on each axis. But it was cutting the circles off at the original 3200 spi too. |
#12
| You could elminate RFI (from the router) as a suspect cause by putting a marker (felt tip/pencil/etc) in the collet and try running again without the router on. Like maybe one axis cable is too close to the router and not the other?
__________________ Experience is the BEST Teacher. Is that why it usually arrives in a shower of sparks, flash of light, loud bang, a cloud of smoke, AND -- a BILL to pay? You usually get it -- just after you need it. |
| Problems aligning motor with lead screw. | SCCoupe | DIY-CNC Router Table Machines | 11 | 02-15-2005 06:33 PM |
| Cutting circles and arcs | Hack | General Electronics Discussion | 4 | 11-08-2004 03:12 PM |
| Problems with ballscrews | JFettig | Benchtop Machines | 24 | 06-30-2004 11:16 AM |
| problems with tuning of Rutex drives | FrankdB | Servo Drives | 2 | 06-21-2004 03:16 AM |
| Accuracy problems | i228208 | General CAM Discussion | 26 | 05-30-2004 01:31 PM |
