#61
| Greolt, Yes, a lens cover would be a good thing to fit. I found a powered USB hub was needed as the camera must draw a bit too much for the USB port on my old clunker of a computer. Windows XP users this driver on my computer Microsoft WDM Image Capture (Win32) Version 5.1.2600.2180
__________________ cheers, Rod Perth, Western Australia |
#62
| I tried plugging my camera into the USB port and then using the "Found new hardware" utility to set it up. I could not find the "Microsoft WDM Image Capture". Is it part of the normal MS XP install or where can I download it, and use it to start the camera? Thanks Hager |
#63
#65
| Hi Mark, Here is a listing of them on ebay. This link will obviously expire after a while but it should be good for a couple of months. here Trick is to unscrew the aluminum cap, adjust the plastic lens by turning about half a turn anti-clockwise as a starting point. Pointy nose pliers come in handy. Don't be limited by this camera as others should work as well. The crosshairs are in Mach3 in the video screen.
#66
| Just bought myself one of these cameras. I havent made the mount yet but its attached to a 5m USB extension plugged into a USB2 port. Unfortunately the frame rate is down to 1 every couple of seconds any ideas how I could improve frame rate? |
#68
| Thanks Rod thats an improvement in frame rate. I have a problem with the mouse move in the video window. The Y axis jogs correctly but the Z axis moves in the opposite direction. Is their a way of reversing this? Also the dro and mouse cooridinates in the video window are not clear. Do you have the same problem? Cheers Liam |
#69
| Hi Liam, Not sure if it will work by try Flip Image and see if it travels in the right direction. Yes my on screen coordinates are not that clear as well. I suspect it is something to do with the video card on the computer. I am at my desk so I don't have a camera connected to try it out but try going into General Config in Mach3 and in Screen Control there are two options - "Hi-Res Screens" and "Auto Screen Enlarge". Try these one at a time to see if there is an improvment. You might have to close the video window each time to test it.
#71
| Hi Liam, The only other thing I can think of is that you might need to rotate the camera in the holder. Place a ruler under the camera and see if it reads correctly for the two axes. If not then rotate the camera until it does.
| BUNOZ-CNC Another Aussie Adventure | Denbo | CNC Wood Router Project Log | 42 | 04-20-2010 07:46 AM |
| TL-2 For The Home Shop: An Adventure In Machine Moving | Geof | Haas Lathes | 9 | 12-12-2009 11:04 AM |
| Another Aussie Adventure in Vacuum Clamping | Greolt | CNC Wood Router Project Log | 134 | 11-09-2009 09:15 PM |
| LatheMaster 9 X30 CNC Adventure | Ron111 | Mini Lathe | 97 | 10-10-2008 09:51 AM |
| Another Aussie Adventure in Optical Edge/Centre Finding | Greolt | Mach Software (ArtSoft software) | 8 | 04-01-2008 03:48 PM |
