| I got my hands on a Dahlgren CNC router for $100. I seem to be very solid and have ball screws for both axes. I am planning to rebuild the third axes so it has full cnc control instead of just on or off (up/down). The motors are Rapidsyn American Precision (Model 23D-6306C, 3.4VDC). As you can see, it runs off Radio Shack TSR-80 and it has a huge controller! The table is 12"x16". It is obsolete and outdate. My question is can I still use these old motors? What kind of controller can I use? Thanks. |
| Sure, those look to be stepper motors. Read more on this forum -- some Gecko drives (or whatever drives are in the machine may still work) should fix you up. Then, use a computer with Mach 3 to do control. Nice find! Ahren www.cncrouterparts.com |
Hey check out this thread. You're in good company. Glad to see someone else has resurrected a Dahlgren from the past ![]() http://www.cnczone.com/forums/showthread.php?t=48718 |
| Back in the 80's Mike Dell was my neighbor in south Austin. I had a computer just like that and didn't know what to do with it, so I took it to him (at the time he had his little enterprise in his garage with a few employees), he saw the machine and offered me $40 for it. I jumped on that deal because it was given to me. As for your new (old) cnc machine.. That looks like a very cool machine. |
| I am finally getting around to start my CNC conversion. The old TSR-80 computer does not work. There are so many options for the step motor drives. I want a good quality accurate and smooth drive. I really like the Gecko G540 because it it all one self contained unit but seems pricy at $300. The preassembled drives from PROBOTIX is a better option at $35 for each axis. I am not really too sure about the $65 3-Axis drive from HobbyCNC. www.hobbycnc.com http://www.probotix.com/stepper_motor_drivers/ http://www.geckodrive.com/product.aspx?c=3&i=14469 What does the Gecko or PROBOTIX have that the Hobbycnc version does not? Is Gecko G540 a really good drive? What are other good quality drive (less then $300) for controlling the 3-Axis? |
| I have the HobbyCNC and it is a great setup. I think the Gecko is a step up at a slightly higher price. I would have bought the Gecko if it was available at the time. Steve |
| If the Gecko is bipolar, then the drive have to be bipolar too. Correct? Is the G540 going to provide more "accurate" positioning? The G540 contains four of our G250 drives. Looks like a single G250 has about four times more components on the board then the single 3-axis HobbyCNC board. Thanks. |
#10
Hi Samim, If you'll look at some of the threads about Geckos, you'll be amazed at their policies. First time - S**t happens - Fix or replace for free Thereafter - Free evaluation of driver. Extremely good customer support. Always polite and very helpful. Have a crazy idea that the customer is important. ![]() Al |
#11
Both designs will give you similar positioning accuracy. You probably end up with about 0.0001" positioning accuracy in a system with possibly 0.001" or more backlash. You don't really need that much positioning accuracy. The HobbyCNC driver uses a pre-configured driver chip and adds a few discrete resistors and voltage regulators. Each G250 uses an FPGA with discrete MOSFETs for the driver. It is really tiny. The G540 packages 4 G250s into a space that is about the same size as the HobbyCNC board. Steve |
#12
| Sound like G540 is way to go. I will take apart the DB9 connector on my motor to see what type they are. Can the Gecko G540 drive Unipolar or Bipolar motors or just Bipolar only? This machine is really old and Rapidsyn is out of business. Do you think the G540 will be able to drive my motors? This machne has manual adjustment for the Z-Axis. I am planning to ad belt drive with a stepper motor so I will have full CNC axis. Any suggestions on stepper motors? Thanks. |
| RFQ: Looking for someone who can make watch hands | amanson | Employment Opportunity | 6 | 07-31-2008 07:26 PM |
| Router Using 3/4" MDF (first router build) | eguy208 | CNC Wood Router Project Log | 33 | 04-11-2008 10:33 AM |
| Using a router for the 1st time. Need advice of cut speeds, router bits etc. | Apples | DIY-CNC Router Table Machines | 19 | 09-23-2006 03:33 PM |
| Surfcam PP for Isel router / Precix router | IvanTochev | Post Processor Files | 2 | 05-12-2004 12:27 PM |
