Old 04-28-2003, 07:38 PM
chuckknigh's Avatar
Gold Member
chuckknigh is on a distinguished road
Why are all routers horizontal?
I was at Lowes today, and was looking at their panel saw -- a gigantic machine designed to handle sheet goods like MDF, which took up remarkably little floor space.
In fact, it reminded me very much of the routers shown here, but tilted up till it was *almost* vertical. It leaned just a little bit -- probably to help the MDF stay put.
The x-axis was just some rollers on which the MDF could slide easily, side to side.
The y-axis was a pair of guide rails with a circular saw attached.
Congratulations -- y'all have corrupted me. Now I'm looking at things like this, and seeing CNC possibilities! ARGH!
Anyway, the basic design seems like it's perfectly adaptable to our little hobby, and it would make a truly large router table practical, even in a small workshop.
Any thoughts? Am I just not seeing the down side to this type of design? It seems to make sense to me.
-- Chuck Knight
Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiTweet this Post!Share on Facebook
Old 04-28-2003, 09:02 PM
balsaman's Avatar
balsaman is on a distinguished road
It's a good idea. One problem could be clamping of the material. A little gravity goes a long way here. Another is lifting the router along the x axis. traditional machines need to lift the router on the z axis, but this is generally 2 or 3 inches so a little slower is ok. This can be overcome with counterweights pehaps?. Why don't you design one and show us?
Eric
I wish it wouldn't crash.
Old 04-28-2003, 09:31 PM
paulried's Avatar
Gold Member
paulried is on a distinguished road
It is a great idea, but it has already been done. Here is a picture of the router from CamTech in Canada. It is called the "Spacemaker" . I believe it is mostly used in the sign industry so cut-outs are are not an issue.
Camtech Industries
Paul Riedlinger
Let the chips fall where they may...I'm not going to clean them up!
Old 04-28-2003, 11:59 PM
chuckknigh's Avatar
Gold Member
I knew it was a good idea!
I can see how having the parts not only come loose while cutting, but falling with gravity, would be an issue...but those are the details. Engineering solves details like that. Looks like they used a vacuum clamping system as their solution, which makes a lot of sense.
On the panel saw at Lowes, they used a spring, not unlike those used on garage doors, to basically neutralize the weight of the saw carriage.
I'm just starting to design a flat, horizontal router...for my initial attempt I don't want to complicate it in any way. But, I still say that this is an ingenious way to design a router, that can fit in a garage workshop.
At this stage, KISS. Especially for my first attempt.
Thanks for the feedback!
-- Chuck Knight
Old 04-29-2003, 12:13 AM
paulried's Avatar
Gold Member
I have one of the panelsaws you saw in Lowes that we brought back from a plant in Mexico.....don't ask, it was a disaster....They work great for rough cutting.
I was on the web site of the company the other day
Safety Speed Cut
and I see they are offering a router, but it is horizontal and looks to be 2-axis not three.
If you are looking to convert a panelsaw to a router, I can sell you one cheap! It only has a few thousand miles on it and was only drive on Sunday to church by my grandmother!
Paul Riedlinger
Old 04-29-2003, 09:09 PM
ger21's Avatar
I have a homebuilt panel saw in my garage that uses rollerblade bearings on 2" conduit. I built it about 8 years ago. Just a circular saw with a $120 blade, but it cuts almost as good as my Delta Unisaw. It's also cuts perfectly square too, great for crosscutting 4 x 8 sheets.
Old 04-29-2003, 10:36 PM
paulried's Avatar
Gold Member
Truthfully, that is about all the Safety Speed Cut saws are. Basically a frame holding a Milwalkee skill saw.
Paul Riedlinger
Old 11-22-2005, 01:55 PM
BCwanderer is on a distinguished road
http://www.otocoup.com/
Here is a link to a french angled router.
It includes plans and ciruits.
To translate - put the site into Bablefish
http://www.babelfish.altavista.com/
Another french CNC site is
http://www.cncloisirs.com/
Old 11-22-2005, 02:22 PM
mxtras's Avatar
Silver Member
mxtras is on a distinguished road
There's a guy on here somewhere that built (or was in the process of building) a router that was mounted to a cinder block wall. I can not find the thread, but seem to recall he was in th UK. Anyone remember this thread?
I ran a vertical Wesflex router many years ago making shutters for Pizza Hut from MDF. One of the nice things was that all of the crap ended up on the floor instead of on the table - that was definately a plus in this case.
A vertical machine sure does make sense, doesn't it? What are the pitfalls? Inertia of the Y/Z carriage? - this could be counterbalanced....what else?
Scott
Consistency is a good thing....unless you're consistently an idiot.
Old 11-22-2005, 03:49 PM
DieGuy's Avatar
DieGuy is on a distinguished road
Cut outs are a problem if not planned properly, You would need to be on the "top" of the cut for sure, and all that gravity pulling down on it may cause a tear out. I bet a vacumn setup would be need to prevent that.
  #11   Ban this user!
Old 11-22-2005, 05:14 PM
greybeard's Avatar
greybeard is on a distinguished road
It was a thread by MikeF, August 2004 -
Not sure I'm ready for this - I've started building!
It's like doing jigsaw puzzles in the dark.
Why is there always more error than trial ?
Old 11-22-2005, 05:26 PM
Bloy2004's Avatar
Fumbling Machinist
Bloy2004 is on a distinguished road
hmmm....I don't think this is the thread MXTRAS was referring to. This machine thread posted above is still horizontal but the gantry rides along the wall. But I do too recall a thread where the router table was parallel to the wall. I believe cables were used(with counter weights) to control the axis.
But the thread for this is invisible to my searches
Horizontal cutting table woodworker2 WoodWorking 29 08-06-2005 10:57 PM
4-5 axis control recomendations for home built horizontal machine Kmed General CNC (Mill and Lathe) Control Software (NC) 3 01-17-2005 05:04 PM
ArtCam with 2 routers? walter ArtCam Pro 9 06-26-2004 05:10 PM
Suitabilty of recirclating ball linear slides with cnc routers (wood cutting) twombo DIY-CNC Router Table Machines 5 03-03-2004 08:35 PM
Cantilevered routers and other ideas... chuckknigh DIY-CNC Router Table Machines 8 05-24-2003 06:41 AM
