Old 06-21-2004, 07:06 PM
kanankeban is on a distinguished road
Where I can buy pinions and a 120" rack online?
I need to get a 120" rack to drive my x axis, does someone knows where I can get this online, or the way to put together two smaller racks forming a 120" inch one...
Regards...
Hector
Old 06-21-2004, 07:42 PM
trubleshtr is on a distinguished road
try McMaster Carr's web site, or Misumi's web site.....both sell lots of industrial stuff at average cost.
menomana
Old 06-21-2004, 08:26 PM
ger21's Avatar
Use a 3rd rack teeth to teeth to align 2 together.
Old 06-21-2004, 08:52 PM
Could you explain how this is done...and is this a common procedure in the big Brand CNC Router Tables
Regards...
Hector
Old 06-21-2004, 09:29 PM
turmite is on a distinguished road
Hector, did you say 120 inches for your z axis? You must be building huge machine, maybe for foam carving??
Mike
No greater love can a man have than this, that he give his life for a friend.
Old 06-21-2004, 09:30 PM
duluthboat's Avatar
duluthboat is on a distinguished road
You can use a short section of the same rack to get the correct alignment of many short ones to make a longer one, as ger21 has said. High end pro machines seldom use racks. Here is a quick example of what it would look like. The gap is over done for effect.
Gary
Old 06-21-2004, 09:52 PM
ynneb's Avatar
Moderator
ynneb is on a distinguished road
Hecktor, Just for your reference, you could use timing belt instead. The belt is fixed at both ends of the machine and loops over a drive pulley. I have used this method, and an very happy with its performance.
I must admit, it doesnt sound that great, but I am so happy with it, that I will be using it on my next machine as well.
If you need more details let me know.
Old 06-21-2004, 11:38 PM
Mike
nop I mean 120" for my x axis....
Regards...
Hector
Old 06-21-2004, 11:41 PM
It will be great to see how the timing belt concept is done...If you have some pictures it will be great.
Is this method more expensive than the rack and pinion option?
Regards...
Hector
Old 06-21-2004, 11:43 PM
Gary
Now I got it Thanks so much...duluthboat
  #11   Ban this user!
Old 06-22-2004, 12:07 AM
Regards...
Hector
Now I'm embarrassed! It's been along day.
Mike
Old 06-22-2004, 02:53 AM
ynneb's Avatar
Moderator
Hecktor I downloaded these pics off a web site a long time ago, and dont know where to now point you. Here are two of the pics anyway.
This next picture also shows a V bearing in the setup. There will be another Vbearing abouve it that is out of site. You will need 8 V bearings per axis. That is 24 bearing for a 3 axis machine. More than you would expect hey?
The only reason I am including my interpretation, is to demonstrate that such a system can be done without special milling tools. I just used a drill to do this system.
Yet another image.
Belt clamps
Instead of buy the belt clamps I cut a piece of angle iron into a 1 inch length and attached a plate to it with 4 bolts. I had no groves in it but tightened the buggery out of it so that it squeezed the belt between it. ( It has not moved one bit ) on the other angle of the iron I put a hole and bolt through it and attached it to the frame. This way I could always tension the belt.
I am so convinced with timing belt. While the belt was sort of slack I tightened the bolt about half a turn and it tensioned up to like a guitar string. This demonstrates that there is un measureable stretch in it. The belts I have got, have steel wires embedded in them.
